i just purchased on second hand and will be receiving shortly.
At the moment i have a R34 Sidemount, but the ARC sidemount (104mm thick core) is 50% larger than the r34 smic.
People say the r34 smic is rated to about 230kw~ so the ARC sidemount should have no issues with that power range.
