Im trying to deceide which plenum to go for.Its either Greddy or Plazmaman.Seeing how the Plazmaman item is only the top half does this mean that the top half of the stock 33 plenum is the most restrictive?
Will the lower intake runners support 500hp?
Both are very good items,will it just come down to what look i want in the engine bay?
https://www.sau.com.au/forums/topic/204727-plenum-choice/
Depends on your choice, but i'd go the greddy. The full intake replacement is best for both big or low power because it will add some responsiveness.
Which one suits your budget? Making 500hp isn't cheap. Add that and you have the answer.
https://www.sau.com.au/forums/topic/204727-plenum-choice/#findComment-3626656
dave you should give plazmaman a go if its not all drag, keeping the longer runners is a good idea for low down. I havent made this decision yet either, but thats because i dont want a plenum that looks like it is custom ie polazmaman's curvy thing. i want one that looks like it 'might' be nissan
https://www.sau.com.au/forums/topic/204727-plenum-choice/#findComment-3631092
what throttle body you planning to run?
Greddy i think is setup for the Q45 - and you need an adapter for the std one
Plazmaman is setup for the std one, im just starting to look into what i have to change on mine to fit the Q45
https://www.sau.com.au/forums/topic/204727-plenum-choice/#findComment-3631104
hypertune has better flow then the greedy item
cost 2200 with any size throttle body
killer plenums but for 2200 forget it in this application, unless your after every poofteenth NYTSKY.
Used one on a 300awkw+ EVO 6.5 TME and it was the best plenum ive seen... the TB was average though.
https://www.sau.com.au/forums/topic/204727-plenum-choice/#findComment-3631170
Topsecret has plenum for around 2K with Q45 Throtle body. looks pretty sexy IMO its the best one on the block in looks and performance. look at nengun or topsecret site.
Greedy I think someone is selling one on this site for $700 i think in perth do a search.
I guess if im on a budget i go greedy if i wanted all out i go topsecret looks dam impressive.
You get what you pay for, if you try to sell it later you will get good return on a jap product than an imitation one.
https://www.sau.com.au/forums/topic/204727-plenum-choice/#findComment-3631231
got power figures & graphs of cars with said top secret plenum?
or are you pulling this out of ur behind caus it looks all pretty?
https://www.sau.com.au/forums/topic/204727-plenum-choice/#findComment-3631337
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
