Hey guys, just wanting some ideas and info on turbo charging my R31 gxe skyline.
So far i have:
R31 GXE 5SPD - $600
R33 RB25 TURBO - $50
VL TURBO exhaust manifold - $50
BOSCHE 040 pump - (borrowed from my rb20det ARGH31)
INTERCOOLER - choice between standard 32, rx7 or supra coolers.
The plan is to run the standard ecu/injectors and run standard boost (7psi). im not realy too afraid to kill the motor as its clocked up 328,128k's as it is and runs like a peice of shit anyway. Also has anybody heard of using RB20DET injectors on the 30ET? i have a set available if its not to much trouble to use them in the mix...
If anybody shows interest il post some pics of the process so they can see how dodgy and cheap ive made it :D:P
https://www.sau.com.au/forums/topic/204734-rb30et-super-budget-project-r31/
just get stock vlt injectors and vlt ecu, i have done pretty much the same except also have a small fmic which i sprayed black... i didnt wanna spend too much as i didnt think it was worth it, hence the budget build lol
seriously... go here
www.r31skylineclub.com
There is more "ET on a budget" threads there that will suit your type of aims :stupid:
lol why were you awake at 3:00am on a Tuesday?? haha.
Anyway, my friend converted his commodore using the rb30 manifold, rb25 turbo + adaptor plate, vlt injectors & ecu.
Jack
Ive decided to go with the standard ecu because the motor already has the death rattles andi'll probably laugh when it dies. Do you know how many cc's the vlt injectors flow? also ive been thinking on maybe just a solder in chip for a vl-t in the standard ecu? I might end up running with a BA xr6-t cooler aswel, depending on how it fits up... im pretty much lookin at tarbinizing the car for under $1000 (including car price).
Brendan :)
Edited by thrashworks
out of those coolers, I'd use the rx7 one if it is from a series 5.
otherwise, poopra cooler (7mgte I assume)
where did you get an RB25 turbo for $50?
the rx7 cooler is a series 4, i could always steal the 600x300x75 from my other skyline as its off the road at the moment anyway. as for the $50 turbo, you gotta love crackheads :)
I sold my 34 and bought a 31 daily, wanted to do a budget build and ended up with an r31 with r33 5 speed, rb26 head and shit loads more other stuff (all still to be put in)...i wish i could tame my modifying desire...
And now im thinking about buying a house instead of a GTR...wtf is wrong with me !?
Good luck with ur 31 though :)
Wouldnt be worth doing the upgrade without the VLT ecu and VLT injectors.
You can chip an n/a ecu to run VLT injectors but you will have no knock sensor (ears should be good enough) - this is a much cheaper option than buying the above for 300. Ebay generally has them for 100...
If you have a death rattle now then I wouldnt bother. Putting in a decomp. plate to lower the compression may also help here
The death rattle doesnt realy bother me, ive got a few spare motors already, so if one goes bang, i laugh, then replace it :) . If the motor works well then i might even add my 20box... My daily driver is a 34GT-T so im just lookin for some laughs and to make ppl go wtf? when i take it to our local drag strip (1/8th mile track hahaha). and :) for the tip on the ECU's , i reckon that'l be the path i go down...
Brendan
    • The team at OBD2 Australia are pretty good, shoot them an email and ask them. I've dealt with them before for work stuff. I'd be shocked if it didn't work, so long as Consult can activate the ABS. But you might need to use KLine for it which would be the stopper, as I don't think that piece does KLine comms.
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
