  • Replies 78
Posted Images
Adz2332 : Hey mate they are Apexi EL 2 (Boost, Water temp & oil temp) i think around $700-800 maybe??
funkymonkey : Yep, if that car is still in good nic, like i had it i would buy it again!!
this is the only pic at night i have.......
Edited by -NismoR32-
Dunno what gauges to get yet.. I like the HKS ones also. And they are a bit cheaper to i think....
Dunno where to mount them either. As on the A piller is a defect, above the dash is a defect. And having a gtr there in no din pocket...
What's legal and what isnt regarding gauge mounting?
i'll probably buy a boost gauge soon, dont think id get any others for now but i was just wondering, what was allowed and what wasnt as far as mounting a gauge goes.
basically (in tassie, prob be the same everywhere else), anything that is 'obstructing' the view, i.e - a-pillar, middle of the dash..
but i've seen some people mount them infront of the speedo/tacho and thats fine...so i assume its anything above the dash lining or whatever..
cheers
cheers
I even believe here in South Aust you cant have any mounted to your steering coloum or infront of the dash gauges either
oh ok yeh prob 'obstructing' the speedometer or whatever haha but yeh ive had gauge on the a-pillar and been pulled over heaps of times and haven't had any troubles..but yeh, i think it all depends on the cop
they look really good, where abouts did you get them and the gauge pillar from?
hi m8, bought the guages four or more years ago from import solutions in the uk, they were originally on my rover 220gsi turbo, they are the 52mm ones, called direct bright meter, dont know if they are still made?
the gauge pillar i made myself, took ages, but definitely worth it :)
looking good mate,
what gauges are these?
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
