Hey all, have done an R33 GTS Auto to RB25DET and manual gearbox, my question is with the brakes. I have to upgrade to GTST brakes, but to get it legally engineered do I need to go to the 5 stud bolt pattern or will the 4 stud suffice as long as calipers are changed?
https://www.sau.com.au/forums/topic/205121-engineering-question/
Calipers cant be changed without hubs, the bolt holes don't match up i believe.
Also disks wont match the calipers width.
So you need hubs with 5 studs to fit those calipers. Its not the worlds hardest job, as long as you have a breaker bar of some description. ie gal pipe.
it is my understanding that if a certain engine was offered in the same body from the factory then you dont need an engineers report.... IE 6cyl->350 chev in a HT kingswood or say changing a deisel gemini to a 2l gasoline engine its not required....so i cant see the diff
This is the reply I got from vicroads when asking about a ca18det into a ca18de silvia for my gf
Change of Engine
1. Replacement engine is identical to the original engine, or is an
option allowed by the manufacturer for the same model vehicle
The optional engine must be offered in Australia by the vehicle
manufacturer as an option for that vehicle (or certified variants). The
change of engine may be recorded by VicRoads provided that the
registered operator or a motor mechanic, or dealer in that make of
vehicle or an Automotive Engineer signs a declaration certifying the
engine is optional for the vehicle model, and that all modifications
made by the manufacturer for the same vehicle model with that optional
engine, have been completed.
But then as a silvia was never offered in australia so...
But sounds as though an engineer at least has to look at it
Engineer will need the brakes done, about the stud pattern, you'd need to ask the engineer that
Being its an import - VicRoads will send you to an engineer 9 times outta 10 as they dont want to pass judgement on imports etc.
If it was a AUS car - piece of piss, but ye. Imports are a pain for that
Thanks guys, I believe the bolt patterns should line up for the calipers, will guess I will find out soon enough. The main reason I ask is that I really dont wamt to get new wheels as the ones on it are quite expensive. Im going to have a hell of a time here in Vic as I have just come from queensland, and compared to Victoria the modification rules are seeming to be very strict. Eg my inlet alone has PWR front mount FMIC, Pod Filter, modded plenum and aftermarket BOV. And the ECU, well I guess I will have trouble transfering rego etc.
How strict is a roadworthy on modification issues, are they concerned with mods or just the safety aspects alone (hence the safety cert)??
the engine number prefix is the same....so i would simply fit the engine...then go to vic roads and have them sight the engine number....then thats it...obviously change the brakes for safety's sake...
This is how we got an N/A car registered with a turbo motor.
Yeah I reckon so.
if he has insurance and wants to keep it he has no choice.
im the worlds biggest fan of moving plates and numbers around but somethings things need to be done corectley :/
im the worlds biggest fan of moving plates and numbers around but somethings things need to be done corectley :)
Who said anything about moving plates and numbers around?????Vic roads dont have anything to tell them a vehicle has forced induction.
An engine block is an engine block and the numbers say that its an RB25 so wheres the problem?
Edited by ylwgtr2
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
    • Hi everyone, I've been wrestling with this for a while now and have been trying to find out the cause. For context, the turbos used are Garrett 2860 -5s, the BOV is a BNR32 HKS SSQV IV kit, the car is currently tuned to ~470 whp on 17.5 psi. The car drives normally, pulls well when it doesn't happen, and I can replicate it fairly easily. It does not sound like turbo shuffle or flutter. The engine has only a thousand or so miles and has had this behavior since it was completed. After my engine was built for my R32 GTR, I noticed that the car now sometimes makes an air discharge sound on what appears to be positive boost pressure that sounds really similar to a BOV. I had thought that it was a BOV issue but even when replacing it with a brand new unit, the sound persisted. It seems like it's coming from the passenger side but I may be mistaken. The closest scenario I could find was this post here https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/ started by @yakshii and it sounds very similar. As in, at partial throttle once I reach positive boost I begin to hear the same psh psh psh psh psh sound like air is leaking somewhere when I keep the throttle in the same position. It most commonly happens in 4th gear at around 3-3.5k RPM and 5th gear around 2.5-3k RPM, which seems to coincide with normal positive boost thresholds. It might be similar to what @Austrian GTR mentioned about his own HKS SSQV. Notable difference would be that when he applies more throttle when it happens, it stops. In my scenario if I apply more throttle during this repeated psh psh psh sound, the cadence of the sound gets faster and louder rather than stopping. If I lift off slightly and apply throttle again, it will normally stop and pull without issue. I've checked all rubber couplers to ensure that they are tight, but have not gotten the opportunity to properly do a pressurized boost leak test. If anyone has had similar experiences or thoughts on what might be the cause, I'd be very keen to hear them. I also have a video of it happening from inside the cabin, if that would make it easier to understand: https://youtu.be/2zqZXcx8jbA
    • I'd want at least $40K for mine, but thats easy to say cos I'm not selling anyway.
