  • 4 weeks later...
  • Replies 82
  • 3 weeks later...
  • 3 weeks later...
news...
well the guys at hills went to the effort of putting developing a plug in loom extension to swap the pins required for the late s1 stageas. What they didn't get sorted out is some sort of difference between the 34 gtt and late stagea coils which caused the #6 ignition chip to burn out after about 30 min. PFC is off for repairs, then a firmware upgrade to sort that, then we will be back in business. 2-3 weeks probably.
this has been a real saga. I recommend aganist buying a late s1 stagea if you are thinking about modifying it - stick to the early model where everything works ok
  • 2 months later...
bloody hell this thread went on too long!
anyway, I've got the car back with the PFC in and all running beautifully. a hell of a lot of work went into getting it working. the good news is I didn't really pay for the development (just a tune) but that means I can't really share the wiring changes (except to say there are a lot). Mark @ Hills Motorsport finally worked through it all and has developed a piggy back loom so the standard wiring doesn't require modification. Anyone with 9/97-8/98 stagea really should talk to him to get it sorted.
The standard auto ECU was working very poorly with the manual conversion (looks like this is another late series ECU surprise). The late ECUs put heaps of timing in over 4000 when it doesn't get a signal from the ECU (45o at 4500!!) which turned out to be the cause of my pinging problem....I had changed the fuel pump, FPR, air flow meter trying to chase that problem. It also runs very very rich (up to 9.5:1) and to add insult to injury the closed loop (02 sensors) turn off over 2800rpm and 1/4 throttle, no wonder fuel economy was woeful.....PFC has sorted it all out perfectly.
I will work out how to overlay the original dyno graph (130rwkw) with the new one, they are a very interesting comparison
Its now making 175awkw at 13psi....which made the clutch slip so boost is back down to 11psi (155awkw). but most importantly the mid range is very strong, and the initial throttle response 1000-1500rpm is noticeably sharper. top end really runs out of puff though.
mods are:
3" turbo back exhaust
11psi boost (greddy profec b)
manual conversion
r34 power fc with wiring changes
intercooler, injectors, turbo, intake etc are standard.
right now it will stay as is, its taken ages to get it sorted after the manual conversion, and now with the extra power, sydneykid's suspension, interior goodies it is very nice to drive and suits it's job very well (towing, moving the kids around and daily driver). I'm not looking to push it power-wise or anything, it just needed a bit more poke than it used to have.
if the opportunity comes up for the right price I will do:
front mount (it was really quite hot on the dyno even at 11 psi.) personally I don't think the 34 sidemount can make enough difference to be worthwhile, but I've never tested back to back
skyline cams and a cam gear
new clutch
highflow turbo
but I am certainly not in a rush.
not sure yet, I am running the first full tank now. welcome to the difficult ecu club btw.
tangles, I've run remaps for years in the race cars and am very happy with them as well. its just that there are some extra costs for the daughterboard/ecu mods in these cars, and they are a little harder to retune. But I think its a very viable option.
nice, Im new to turbo's, and I definately suggest a Toshi remap in conjunction with a piggyback such as safc/sitc, emanage ultimate, haltech interceptor etc.
mod chip plate is a cple hundred, chip and tune is the same, plus soldering costs for the mod chip plate bracket holder
mark @ hills is also looking for someone with an auto that wants to run pfc. they have done a lot of work on running pfcs with the auto trans computer and need a stagea to get it sorted out
Got my car back today and it feels totally different!!! Here's the work I had done:
FMIC installed (finally!!!) - GReddy Spec R-HG return feed kit;
PowerFC installed and tuned (finally!!!);
X-Force split front/dump pipe;
X-Force high-flow catalytic converter.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
