Originally posted by Initiate
Agree on the waste of a nice car, but shouldn't the emphasis here be on the poor sod who probably isn't alive anymore, or at the very least very seriously injured???
Amen brother!
screw the car, i feel sorry for the ocupants.
https://www.sau.com.au/forums/topic/2054-funeral/#findComment-38065
Originally posted by carlo
Thats what happens when you lose control of your car. If your not in control then your not going to have much luck.
The 2nd photo is a good example why we have to have intrusion bars on our imports. Why they dont have them in japan is beyond me.
R33's and R34's have intrusion bars as standard.
It's a cold hard fact,,,if you race hard on the street that sort of crash is always a possabilty....The 1st cars not that bad,,,,the rear end has absorbed most of the impact,,,the o/s/r 1/4 has done its job very well. As for the 2nd pic ,,,well hope no-one was in the passenger seat,,,,. I see this crap on a regular basis,,,,We actually drive a VERY safe cars......Sick person I am,,,,,can I have the Wheels off the 2nd car,,,they look okay.
Neil.
https://www.sau.com.au/forums/topic/2054-funeral/#findComment-38883
Side intrusion bars would (and did) do sweet FA on the car that poled the passenger door!
Just thought I would make mention of the two pictures I contributed to wreckedexotics.com :)
http://www.wreckedexotics.com/cars3/new/35..._071902_04.html
http://www.wreckedexotics.com/cars3/new/35..._071902_03.html
https://www.sau.com.au/forums/topic/2054-funeral/#findComment-38954
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
