  • Replies 118
Hi Sean,
Is this a series 1? If so, do you have the plastic key hole cover as below? (Or if you know it'll fit a series 1)
Sold already, popular item sorry.
  • 2 months later...
  • 2 months later...
hey mate not entirely sure if u still have anything from the car or even if u still have the car at all..... but i was interested in the cooler piping that goes into the plenum in particular the pipe with the bov adapter and plumb back setup and how much u were after for it if ur interested in selling it..... also where abouts in sydney are u for pick up of parts???
PM SENT
  • 1 month later...
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
