  • Replies 103
GRIM we can do this cod. please pm your details to me!
BMAN yes, gtst = ecr33 thats the one you need
power fc is still avaliable
grim, if you read this, im going out now, i will take the stick with me. if you call me before 330pm today brisbane time with your address, i will send it to you today. i have to go out to send pranks anyway. 0417755890
Just a friendly post.
I have installed a C's short shifter in my R33 gtst and am VERY pleased with the differance it has mad to the feel of the car. No noticable wear on syncros (sp?) yet. Would recomend these to anyone.
yep... i've decided i'll have one of the ECR33 short shifters for my R33 Skyline... i've been putting off getting one for ages now, and this is $50 cheaper than i've been able to find anywhere on the net!
So put me down for one, i've sent a pm!
Cheers,
Andrew
thanks al for your comment! much appreciated. ive got one in my r32 gtr and it has changed from a sloppy shift to one that is accurate and definite.
GIjor33 please email me your address and i will have it mail to you tomorrow.
to those that are interested in frieght charges.... i sent PRANKS short shift today COD and the frieght total was about $19 including insurance to sydney. i would say melbourne would be pretty much the same or a couple of bucks dearer.
warrick, sorry it was first in best dressed. and that was B-Man. he has PM'd me his details and i will send it off to him tomorrow. i will however keep an eye out for one for you.
Grim - yeah i will fit it myself, i will also take piccies of the whole procedure.
a mate has fitted one to his GTR and it was so nice! i will also get him to help.
prank you will have yours very soon! give me a buzz if you run into problems. you will need a set of needle nose pliers, preferably one with grooves all the way to the tip like a leatherman or something. should make things a lot easier
    • He's right ~ there is no 'magic' with stuff like this ... it is more likely that in the process of looking for the short, the loom/wire 'incidentally' got moved in the process, thus removing the short ~ now, that maybe a wire (in a loom) rubbing against the edge of some grounded metal, that's worn through the insulation, causing the (now intermittent) short to ground. If one wire in a loom has been damaged in this fashion, it's reasonable to presume that other wires beside it may have also be damaged, and now exposed...you can bet the green crusty copper corrosion will start... ...that'd be a pisser, Murphy's Law steps right in as GTS observes...but worse, something like that is easier to find when shorted...ie; unplug bulb and fuse, and put multimeter in continuity mode so you get constant beep, and carefully poke about hoping to find if some movemet of the harness stop the beeping.... ...it's still all a bit Arnie tho' ..It'll be back... 😃
    • Yeah, but knowledge of one wire's insulation worn through to short on earth implies the possibility of other wires doing the same. I had my power steering die, because the wire that runs to the solenoid valve on the rack runs in the same loom as the power wire for the O2 sensor. And when the O2 sensor/wire did something stupid and burnt part of that loom to death, the only indication was the shit(ter) fuel economy and the heavy steering. It took deep excavation of the looms in the bay to find the problem. Not wear through in that case, but similar shit.
    • Ah, I thought he'd wired it to one of the spare ECU inputs! Too long ago since I read that post, ha ha. I've been arguing with radiators, harmonic balancers, alternators and rust since reading it.
    • Correct. The ECU cannot read oil temp. (Well, I think it probably can in some situations. I did have the thought of potentially repinning the ECU when I was doing oil pressure). I am using this into the MPVI dongle, so that the MPVI dongle can read oil temperature. It is attached to a VDO gauge which is obviously calibrated to whatever curve the sender actually is using. This would be easy if I could setup a table of voltage to temperature like many sensors, but it appears I cannot do this and can only setup the transform rule which appears to be Input (voltage) x Multiplier, and add an offset. This to me means it MUST be linear. So it may be a complete waste of time wiring this into the ECU. The idea was that the MPVI3 has standalone logging. I wanted to use this instead of a laptop with serial cable (for wideband) for long datalogs. Given the wideband also has electric interference, I may never trust this either in a world where the serial wideband and the analog output wideband do not agree. Last time I did a trace I could see the two wideband traces follow each other, but one was a little leaner than the other. I plan on playing with voltage offsets and actually driving the thing to see how close they correlate. If they never correlate... then, well, maybe I'll never use either. Ideally I'd like to have the Analog wideband read ever so slightly leaner than the serial one, because the serial one is 'correct'. Tuning the car to be ever so slightly too-rich would be the aim. Not needing to have a laptop flying around in the footwell connected with cables is... an advantage. About the only one from the forced upgrade to MPVI3.
    • Hopefully not, since he knows the fuses work ha ha ha
