1st you might wana whipe everything down with a damp cloth and a bucket of water. Then if there is any staining use some degreser on another cloth and rub it in then whipe down with water again. Don't bother going to the car wash and sparying that high pressure hose all over ya engine, you can easily F**k ya engine up. Don't risk it. :)
well you are getting an R33 right?
so you could just drive it in to the ocean.
that is the whales natural stomping ground.
Just open the bonnet before driving in.
should give it a good clean
LOL, smart ass.
My car is pretty quick for a whale so SHUT UP!! ;)
Love you man.
For the detailing just use some good metal polish and paintwork polish and hit everything in the engine bay with it, comes up nice and new :)
At least the Japs won't go whaling their own kind.
5 dolla they love u long time!
jus use metla polish and stuff like that....work thru each part of the engine bay and anything with really bad stains use degreaser and then wipe it off afterwards then continue the process!
lol funny man
Thanks for the appreciated respones people.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
