:D
Saw a bunch of imports today, notably a black 32 at Birdwood and a nice silvia whos driver gave me a wave while I was heading thru chain of ponds.. sorry i didnt wave back, but you'd passed by the time I realized :)
-D
Woot! I think this is my first ever spotted :P
I was keen but when I realised my lane was blocked several hundred metres up I gave up! I had to do the double take when I saw the SAU sticker on the Ford though!
hehe, wouldnt be the first double take
theres a holden ute gettin round with SAU stickers on it too :)
Saw this morning a white R33 gts't with a GTR front bar and wing, waz turning from a side street onto goodwood road. Just south of the tram line. Looked tough, was very nice. I was walking up the otherside of goodwood road across from you, dont know if you saw me tho. Waz it anyone on here?
about 45 mins ago, white stagea turning off nelson onto wright rd at the roundabout there, had kit and some kind of dark coloured rims, didnt get a overly good look but looked tough.
might of been Mel they had the Blue R32 and possibly also a midnight purple GTR when they had child they got a stag :down:
this morn on way to work spotted a maroon 33 at the lights on lower north east road with a SAU sticker on drivers rear quater window.
then on the way home saw a silver 34 with a nice kit crusing on walkeys road with a blonde driving.
spotted (a few times) a blue later series R34 (different front bar) GTT in bayside blue with GTTR-34 plates around the windsor gardens area
and at sir donald bradman drive up near mile end bunnings an orange 34 GTT with what looked like vic plates SKYR34 heading towards the city bout 2:45pm
Hey hey spotted you too but I was way too tired to realise until it was too late!
spotted a purple R33 like Jasmin's unless her sister is driving her car :) GTR wing on the back pretty sure id was midnight purple too not some respray
also spotted the micro turbo's today
this morning a mirage turbo and this afternoon a civic turbo :P
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
    • One way of putting the fuel surge idea to rest, is that even when in neutral/clutch in or free revving it still has the same issue, it can’t even get to limiter (7800) so to me that says it can’t be g force, I’m not trying to argue I just want to find the f&$king issue 😡
