went and watched a mate play in the C grade local footy today at the hectorville footy club. 3x white R33s in the parking lot (including mine). one was auto (as i took off behind him after the game)
spotted matty T last night in rambo's ambo.....i was in the corolla so i thought id salute with a traditional keybang.
ow my freakin ears.............i come up next to ya and gone "wait for it.............."
BANG!
:cheers:
Pulled up next to a black Stag in the GTR on Anzac last night at the Morphett Road intersection - think he must've thought I wanted to race down Anzac Highway on a Saturday night with cops everywhere........ I had more fun watching the car full of kids in the white corolla/corona or whatever it was station wagon with HKS stickers plastered all over it! :cheers:
spotted a clean stock looking blue/grey/silver (hard to describe the colour) 32 at virginia yesterday arvo (in the Woods Rd / Penfield Rd area). Was working on my car and heard the note of an RB..........not bad at all
Spotted a silver 33 on Salisbury highway? (going to Pt adelaide) waiting after the mawson lakes traffic lights for another silver 33 to get across. I was in the 4x4 going the opposite direction and didnt recognise the driver but saw SAU stickers.
saw 2 r33s one maroon, with 34 gtr rims and ET sticker on the 1/4 and the other was white both turning off SE freeway onto portrush rd a bit after midnight last night. also another white 33 on glen osmond rd.
think i might have pulled up next to matty 31 in town the other night, gave him sum spool up in his window but duno if he was into it or not haha!
silver stag with gold racing hart rims? yeah, ya were next to me, was in my own little world. Ya drivers headlight needs a bit of re-aiming thats for sure :happy:
Spotted Brittz just then on North East Rd, gave ya a wave but I was behind you in the Daihatsu Applause, I think you must have been like WTF??? Then only seconds later Kye in his ride going the other way, got off a wave but I think it was a little too late
few spotteds yesterday..
Red 34 with i think a black bonnet turning onto hindley yest arvo bout 6ish
Bayside blue 34 GTR V spec with gold drifteks on jetty road last night - HOT
Black 32 gtr with dish rims go past us near botani gardens bout 8ish
Also, on hindly bout 8ish got an enthusiastic wave from a guy in a silver 32, assuming they on here from the wave we got. Waved back but might not have seen me.
haha sorry mate i didnt see you. hiding in that applause again :happy:
saw many a skyline today. from what i remember, a black 33 gtr with gold bbs rims at marion today, a black 34 with uras front bar and chromies at the carwash on north east rd, a silver 33 took off after the black 34 did and one really odd white 33 with what looked like the graphics from 2fast 2furious's 34 on it :s
also saw jaymei in his new stag on marion rd, well missus pointed you out as you went past ;)
probably more but nothing that i can remember
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
