So mine isn't tasteful? :P;):(
I haven't seen yours nightcrawler, it's just my opinion, no hard feelings to anyone.
I spotted 2 Purple R33 GTR's today, One down a side street in the industrial area behind the Airport, had grey XT7's on it. One Driving along tapley's hill rd heading towards the airport with gold meshies on it. Both very hot cars.
spotted vu on grand junction rd this arvo, out the front of some asian grocer?!?
you know what i did after i seen it.........
You spotted me and went fap fap fap? I dont know whether to say ew or thank you! :) :)
If it was next to Foodland and infront of a pharmacy that would be me.
Spotted Andrew today and the Enffue on Salisbury Highway, car was looking nice buddy, looked clean for once too :)
haha lucky you didn't see it close up bud! (It's not really that clean).
Hope the funeral was bearable ....
Yeah, went as well as a funeral can I spose, atleast all of it is behind us now. We can now focus on moving on and healing... I know it took a lot out of my mum so it's good to see her a bit happier now :)
spotted a stag this bout midday near plaza i think it was rss or rrs 250 it was black with a female driving i waved no reply
On corkscrew rd waiting for classic adelaide cars some tool in a black 33 having a bit to much fun with about 100 odd ppl there def did its bit for our hoon stereotype
spotted that 33 gtr parked just down the road from plympton cash and carry
tonight we [kyrian and I] saw:
black/dark coloured R32 or R33 [it was night] turning left of O'sullivans beach road onto brodie road...we were waiting for the tow truck to tow my b/f's toyota that blew up. we saw a few others there as well but didnt really take much notice [the toyota was smoking and kinda in pieces]
another black/dark coloured R32 on chandlers hill road, heading towards south road
saw a yellow R34 parked in daveys road [sexy thing :blink:]
someone may have spotted us looking like idiots on o'sullivans *laughs* a silver subaru with hazards on near the brodie road roundabout...stupid boyfriend and his death trap [toyota corona]
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
