Spotted a red commodore ute with an SAU sticker on it, around 12 going past TTP.......... is that still yours Matty 31??
nah glen, not mine anymore mate. still reppin the SAU stickers kinda scares me but LOL
new tow bitch is much better :O
yeah maybe the think the SAU = Sick Arse Ute :banana:
hahaha good one ;D
-D
EDIT: ironically that just reminded me of an ss commodore ute with the number plates 'uteruss'
i lawld.
Edited by Dohmar
Spotted Donnon leaving his place this morning in the 35 and I nearly shit myself :banana: There I was working away on the place next door, then I hear this car start up with a sweet idle, it got my interest so I peaked around the corner and there she was, in all her glory.
I don't car what anyone says, that car is sex on wheels!
Saw a black 32 gtr on the way back from Modbury around 1pm
Saw a police car follow me over the course of 6 backstreets about 20 minutes ago. They didn't pull me over tho, which was weird I thought *shrug* they were pretty close to me, thats for sure...
Either case, they kept going when I pulled into the hot dog shop at collinswood heh...
-D
got a wave from a black skyline the other night, i think it was last night? very vague i know, but if u own a black skyline and waved to a white 34, hey :blink:
Edited by Damo_R34
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
    • One way of putting the fuel surge idea to rest, is that even when in neutral/clutch in or free revving it still has the same issue, it can’t even get to limiter (7800) so to me that says it can’t be g force, I’m not trying to argue I just want to find the f&$king issue 😡
