keep spotting a black 34 GTT around the port rd/south rd intersection most days after work about 5 15... this guy drives like a twat... if your on here mate, 1. you cant drift or even hold a car sideways for shit and 2. you almost took out my rear quarter the other day, wayy too close and im not Fkn happy :)
spotted a White R8 on greehill rd, not a big Audi fan, but damn that car is nice looking
Spotted a P plated V35 silver one
Spotted a wine R33 in seaford gave a wave nothing
Spotted a Silver R33 parked near me at the Airport plane watching spot after 5, gave a wave, got one back. photo coming soon. lol didnt want to bother you looked like you were on the phone ? anyone here
Spotted a wine r33 on tapleys twice same time
Spotted a Black R33 (GTR maybe ?) took your photo will post soon. anyone here? I was the one in the R34 parked taking plane photos at the airport ?
Spotted a hand waving to me when i heard the RB go past..lol on tapleys, Black R32 no wing heading toward the port, too far away to see who it was?
Spotted a dark grey R33 with flutter heading toward Glenelg on tapleys
within 20 min I saw at least 20 Skylines .lol could of started a cruise..lol
Spotted a dark grey R34 4DR parked in Morphett vale near Emu.
Spotted a silver R33 in seaford
Spotted twice today Pearlish silver Stag in Aldinga got a wave once? who is that, anyone here?
spotted a 3 car pile up too.. people not paying attention on Greenhill rd. and the worse drivers on the roads today, damn oldies drive erratic.
spotted a new 2009 Mustang today , in a weird green colour heading towards aldinga, first time to see one in person, looks a hell of a lot better then the past few years models. but it still a Ford..lol
Spotted saphire at the airport taking photo's. I was in the black 32 waving like a crazy man
so it was you, I heard the RB after you went past, and saw the arm flailing out the window..lol waved back but not you saw me...lol
finally someone spots me and posts it up..lol
and damn the PAT river sticks , smells like a toilet ..lol
Edited by sapphiregraphics
photos of the spotted cars, lol
anyone here ?
Hahaha I saw ya too Troy.... looked like cleaning his car rather than taking pics!
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
