Oh, Also spotted a Wanker Commodore driver in Seaford, didnt give way at a roundabout, i almost went into the side of them... License plate is GTR Something Something
I know the one, they live in seaford, i used to have a gtr commo shitebox, saw it yesterday in anglevale with burnout treads on the back?
spotted a worn out looking, real dark grey or faded black r32 no wing in maccas drive thru about 830 in seaford, and the normal pack of wanna be racers hanging in the parking lot, yelling at me to burn out,,yah right??,,,,NO!!!
willal's one seemed a bit quiet on the track didnt it
An admirable trait as far as I'm concerned
You don't need to be obnoxiously loud to have a shitload of real, hardcore, unfettered POWER
An ideal trait for any street legal car imho.
Or maybe I'm biased ... i really love sleepers... perhaps due to my loathing of wak bodykits
-D
Got that attitude from a 4WD bitch last night. Using the size of her vehicle to manipulate people. Not me.
Liana vs Landcruiser :P
lol you should see dato vs 4wd, regular occurance quite classic when they realise after coming close im driving a $300 rust bucket that i can easily replace and there bumper prob cost more.
^ gtr commodore badge of mas respect, there's a chick getting around with red gtr commo with a massive gtr sticker on the rear. i lol'd at her
yep, funny story, ford sold them ??? kitted up VT v6 executurds they couldnt get off lot,with limited numbering R8 body kit, mine had roller rockers and extractors, gotta say Holden is built way better then GM usa cars, decent big car, but worn out at 160,000k..lol
vt's love to blow alternators at 160,000kms , mine and my mates blew at the same time haha , same colour aswell
but not execturds :P
mine blew on my wedding day on the way ,, a sign for sure..hahaha
Spotted me getting pulled over by the police last night at 2.30 am. They kind of caught me by surprise turning right onto Park Tce from Port Rd and they were next to me then I'm thinking they were in the lane next to me then I saw them literally on my rear bumper with the lights going. Funny thing is they pull up alongside me and no one actually got out of the car.... ask for license and I pass that through the window then asked me why I hesitated from the lights and had I been drinking. Run my license and details through the computer and then they get a call, so pass me my license back and and say goodbye. I don't think I've ever seen a VE V6 go that hard....
Spotted a nice silver stagea on Henley Beach Rd at Lockleys around midnight too
spotted a white r32 on salisbury hwy this arvo along with a silver r34 4 door
on kesters rd spotted a black r33 and a silver r33 with a black bonnet (not sure if it was carbon fibre or not, didnt get a good look)
Spotted GTR Pace Car @ BP West Tce, Cara should have some pics up soon. And yes, filling it with Ultimate not E85, you'd think for the sponsors they would of had it tuned on E85!
im sure they would have if they could justify spending an additional $10,000+ on a $150,000+ safety car.
Edited by scandyflick
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
