Yeah I know....did you see that cop following me and checking out the angle of the trailer (rear of the trailer 1" off the ground while the draw bar was 1 metre off the ground).......just didn't look right, lol
I noticed the cop just as i flashed ya LOL.........thought they were having a good look at it. At least they could see it was hooked on properly tho :)
XXXi is RB30e auto but incredibly clean...the previous owner to the guy thats selling it now completely retrimmed the interior...and also entered it in a few shows....excellent starting platform for something that needs a turbo...
yeah I was looking at it for a daily driver, super clean R31 , didnt make it to look at it , a close person to me is in ICU at flinders fighting for her life in a coma . so things are on hold for now
think I spotted you sunday nugzy down south ?
spotted RBT hell on beach rd and more on dyson rd near maccas defecting cars yesterday. had a red ford falcon pulled over, while another skyline drover past him , being dead silent with his clutch in....hahahahaha not me either ....mine was home
spotted a dark grey r32 4 dr, chick driver with baby gear in it, states rd
spotted a R34 ..black gtt with similar wheels to cara, on sheriffs rd. holding up traffic while driving on the phone ???WTF
Spotted white r32 with giant nismo sticker on it, at his workplace near norlunga, nice guy talked for a bit
spotted Abe's r33
and his look alike car again near noarlunga
think I saw kidfa in his stag ???
Very nice silver R34 GTR with plates VSPEC-34 or something close heading south on Tapleys near Fulham shops, looked fat but not sure if I'm keen on the LED tail lights. Then a silver R33 GTR heading west on the Port River Expressway around 9, looked like it had a couple of bodies in the boot!! Ass was looking a little low :devil:
Also this below - what's next??? Undercover B-double?
i was in the falcon down at aldinga for footy til round lunchtime....pretty sure whenever i was out, i was in the falcon actually
spotted Abe's r33
That sucks, hopefully she recovers.
That R32, is that the one near where i am? I think that is the same one i see around my work. Does my look alike have 18/19" silver rims? if so i know the owner.
Btw, i need to speak to you soon about doing some carbonfibre work for a Pod heat shield.
Oh yeah... also spotted at Munno Para earlier this morning - yellow R34 with fail-spec chrome tail lights, fail-spec bodykit and numberplates HSVEATR(something like that)... someone tell me that thing has atleast 400kw at the wheels please.
See that car alot Vu, not sure on specs though. Just hope its better under the bonnet than it looks from the outside
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
