bought me a stagea a few weeks ago and luvin' it... a little more zippy than the split kombi i was driving previously.
spotted a white stagea on north east road at hillcrest just this morning. had some nice looking lanterns. does anybody know if there is hid or xenon kit for these cars or is it just a matter of putting some decent globes on the factory units?
Haha, yeah the missus asked if I knew someone with the plate "Mudmuncher" and I corrected her by saying it's "Mudhunter" :)
The young fella recognized you and waved though.
wasnt sure if i saw him wave, but :)
oh, and spotted ENR luke with dan riding shotgun on hindley last nite
was in amongst a bunch of falcons LOL
Edited by Matty 31
Saw a Bayside blue 34 GTR with bronze coloured wheels at Domino's on Glynburn rd Firle last night, possibly George or Theo Spartalis? And a sweet R31 coupe at K-Mart Firle on friday night.
just spotted an awesomely immaculate white 34 with white rims crossing south road onto doctors road, hackham....i havent seen a 34 that clean for a while....looked like the whole car just came out of a paint shop...sooooooooo clean.....made my 31 look like crap :)
I think it was me ,,,,,lol
saw luke changing my brake pads, cheers buddy, dans front drive shaft sitting on the table and danai in his 33 yesterday hope the jacks went down well.
brakes are in danai and no squeeling :)
Edited by Import S13
Seen a nice red/maroon 32 on Hindley friday night, with VS KF's on it, looked hawt.
Also seen a silver 32 four door, not sure what road he was on ( I'm not right up with Adelaide roads ), but I was on Marion road, he had what looked like those wheels that Wheelworx had made, the ones that look like D-Teks, but better. Had a big "PITLANE PERFORMANCE" sticker on the side skirt. Looked sick
what time in the morning cos was it about 3-4 cos i was out around then
Some S2's come with xenons standard.
saw a black stagea with 34 gtr wheels on main north road/regency road yesterday early arvo. i was driving white ute filled with tyres that was turning right to regency.
Saw that too, looked awesome.
Spotted an oldschool exotic cruise this morning...had the only new Ferrari infront of me, an old porsche infront of that and an old Ferrari behind me... they all met up with more old school exotics near Parafield Gardens area.
Mine has Xenon's but the the globes get taken out for compliance.
Spotted today a Bayside blue 34 4 door at Belair, white 34 2 door driving behind me past Windy Point and red Stagea (RSFOUR) going up Flagstaff Hill rd
Spotted a white 33 down at Autobarn, looked nice :bunny: Who's the chick if it was anyone on here? o.0 I was in the black 33.
Also spotted Night Kids at Strathfield carpark, may have been same one?
Edited by Ps33
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
