Spotted (probably the toughest I've seen) white 33 GTR yesterday on NE Rd, near Plaza Holden at around 3pm ish. Haven't seen this car or pics of it before. Had Tomei deacl on front fender or door.
That would be Vince's, he has an RB29 under the bonnet too :down:
Christies downs you say.... Where's that :)
Down south :down: dw they were prolly salisbury scum coming to you to see what they can steal
nah christies is worse than salisbury.
southern bogans have made us northerners look placid and well mannered :)
Saw you too bud! Yeah I'm a huge fan of the sound too, AM Performance strikes again :):down:
hahah yep sure does.... picked up mine from him on sat... its a lot louder than i thought it would be but the work is amazing...
also spotted a silver 33 on the grove way by the bp about 15 mins ago
Yeah I saw your car in there while he was working on it. Definitely came up nice!
Spotted a few old school cars and a ute all with hydrolics last night on Rundle St. Put on a real good show at the lights hahaha
if you seen an old white 57 chev that was me and my new wife in the back. we had our wedding that day and went down rundle st that night on the way to our hotel.
seen in auckland yesterday a crap load of legnums, a s1 stag, a r33 4dr with a taxi sign on it and yes! 2 r34 vspec2 in the same driveway. thats right 2!
im in canada now for 3 weeks and im yet to see anything good besides alot of dodge and chev suv.
You clearly don't live South, then.
lets just say, both suck and the remnant overflow ended up in the middle of town..lol
really the stupid crime here in adelaide is rampant, graffitti, car theft,robbery, break ins.
you need a "make my day law" and a legal system with teeth for crims
found two piles of tools the crim was trying to use for slim jim the door open, the alarm saved it both times before damage was done. persistant pricks , next time they get a bigger suprise then a siren,
same car was attempted carjacked in front of Christies beach cop shop in maccas car park. about 10pm one night by 10-12yr olds, got in the car and demanded her to get out. ???? WTF savages
road kill is common in canada.lol so are pickup trucks and paddock bashers
hitting a moose in a skyline wouldn't be a good thing, hence the pick up trucks. go to Billings Montana to see lots of hotted up cars. and women ....not far from Canadian rockies
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
