M35?
I've got one, and I wouldn't think there are too many pearl white M35s in SA...
Nah negative mate was an earlier model (c34????)
Spotted today at toll fleet dry creek was a white 32 with black bonnet
Got it in one champ... I dont have my GTR up here by my mate (Dumpe on SAU) has his 34 GTR here. We often see this white one parading through the streets, keeping it in 2nd gear, launching and revving its tits out down the main street... Waiting for it to go boom one day.. There is a couple of Skylines up here though
Cheers
Matty
Aah nice one man, I highly doubt that this twat were talking about is my mate, l with he lives in andamooka and we always kept that sort of behaviour on the dirt. You learn how to control a car much more that way in my opinion. If you're getting any repair or paintwork done at Roxby Crash Repairs ask for Fred and tell him Matty Sherlock recommended him (he's a longtime family friend, and will do the best f**ken paint job that side of the desert ) :thumbsup: Also not sure if Johnny is still up there getting around in his white 33 gtst? First skyline I ever experienced boost in :worship:
Heard an rb of some description on the dyno aswell, sounded very nice..
Spotted white r34 with prime on number plates on north tce in city
did it have a transformer sticker on it?.. theres a 2 door 34 down my way with number plate either prime or prime34, and the owner has covered the bonnet in a huge transformer sticker, way to ruin it...
Spotted: White 34R with black rims, a red 32 possibly a GTR and a green? 33R last night, first 2 were cruising Anzacs and the 33 was spotted on Hindley Street..
A red 35R heading towards the city down the freeway, always see that one on the freeway..
And a red 32 going past IKEA at 4am yesterday morning..
One contender that springs to mind is an r34 getting around Adelaide with what look like 58' chromies. Spotted him the other day and jokingly asked how much he was selling the car for. No offense to the owner but IMO a wheel/tyre combo like that defeats the purpose of the car and belongs on a civic or in Jennas reference 'hot4's'
She's still got her old one but she's also got a magna wagon. Was a good idea with the dog but my 4WD works just the same.
4 cars between the 2 of us isn't ideal haha going to start selling them up soon I think.
Edited by Import S13
Yeah it had a masive transformer sticker on bonnet lol
iam seeing this so much lately .........is there something iam not getting ............is it like the rh9 thing takes a wile till u work it out then realise its actually a badge of respect :teehee:
cause the stickers seem to be on hunks of junk :wacko:
maybe someone can let me in on the joke ...........iam not quick with the up take these days :ph34r:
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
