what you doing back on the road in the gtr, i thought we had a deal black heart, WE HAD A DEAL :happy:
guess its finished getting fixed :wub:
Yeh all fixed. Posted some pics in the all type crash is the bomb thread if ya want a look. Only going from one place to another lol.. be sitting at home for a few months now :) poor car, just gets going again and it gets put away again, must hate me atm..
yeah a white r33 but standard plates
Ah ok.. Used to see one every morning going down south road with BOWDOWN on the plates. Had a fat drift bodykit on it, thought it might have been you..
yeah spotted a wine red 32, a dark blue 32 gts-4 and a white 33 last night at west lakes. wonder what you guys were doin :D
HEY!, i seen those cars to, but the gts4 was black, not blue :D
LOL!
Yesterday at St. Agnas shops, I saw a dude in a white 33 with a SAU sticker on the windscreen. Gave a wave, got one back. :teehee:
And from what I can remember from lastnight when I was in town for a mates 21st, I saw two 33's (one white, the other silver) cutting lap after lap on Hindley along with a grey 32 GTR with a nice set of rims. Ended up parking behind a Orange 33 on Hindley.
Oh, and I've been told I ran into Dan (gzilla) and his missus. :banana:
Kye
spotted flicks car in your new work car park.
the cars from the drift demo out at mallala today were being defected as we left the track :teehee:
the cops must need to make up there monthly quota of defects.
how low is that? you went to the track to do it legally, or spectate legally, and they still punish us for it.
R-E-V-E-N-U-E :banana:
Doesn't mean you you can drive an illegally modified car on the street thought. when will people learn this?
well if its a purpose built track car on the street then its a different story.
but what your telling me is, you dont have one, not on, illegal modification on your car?
think hard.
think hard.
of course i do, coilovers, power fc, just to name a few, but if i get done then thats my bad luck, i wouldn't winge about it, cops are just doing there job, trying to keep people like me and you safe.
i agree mate, but when they sit outside of these events, waiting to randomly select a car for a new sticker on the front window, it gets frustrating,
how would you feel if it was you? lets say you went to watch, and as you where leaving, in an orderly manner, they pulled you in and slapped you i the face for a defect? you would be pretty cut right?
its like taking candy from a baby for them.
i think i spotted you on friday morning to..on regency road? i was in my company (seina foods) car.
im pretty sure it was you anyway.
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
