hey guys,
bought a brand new xforce highflow cat off Ryan1600 and put it on the car tonight.
With the new cat on, even with the gaskets, in the middle of the ovals on either side that join to the next part of the exhaust ( the part furthest away from the bolts) I can put my hand under there and feel some of the warm exhaust gases blowing out in the crack.
Just to make it clear... so if the top and bottem of this oval are where the bolts are, the part that I can feel gases is ... ---> () <---
Is this acceptable or does it have to be completly sealed? and if so, wot is the best way?
And I tightened the bolts up hard enough to squish the bit of the gasket around them, but not in the middle.
1 other thing, my old gaskets appeared to be larger then the ones that came with the xforce... should those maybe go back on?
appreciate the help :)
Adam
https://www.sau.com.au/forums/topic/205808-question-about-exhausts-and-joins/
The flange on the existing pipes has probably warped a bit. You can get special high temperature sealant (like putty) that you can coat the gasket with. That should help create a proper seal at the flange joints.
Thanks guys, appreciate the help.
Can I drive the car around for the day as it is?
is it possible for me to put two gaskets on? ie, the old + new one? or is that a bad idea? because by the looks of the old 1, with that combined with the new 1 it should be a good fit.
just use that exhaust gasket goo stuff. it's only about $10 a tube. put it on the flanges and use a gasket as you did, and hopefully it will seal. if it doesnt, you'll need to find which face is warped and get it machined flat. well not even really machined.... you could prob do it yourself with a grinder and a steady hand.
Edited by Munkyb0y
I will go out and get a tube of that stuff ( sounds like it could come in handy) but I just chucked on the old and the new gaskets together and it now appears to be fine :) I may still put some stuff on it just to be safe.
Thanks for the help guys ;)
You'd be better off with two gaskets. Goo will take weeks to get it hard enough to be heat resistant. Usually melts or burns out - and its messy
If you machined it flat you shouldnt even need a gasket as the materials are the same and will be running at the same temp
If you pull it off yourself it would cost less than the goo to machine
The stuff u need to buy is CRC Maniseal Exhaust Cement!
u use this stuff on both sides of exhaust gaskets and as the first time the pipes get some heat in them this stuff will set and stop all those unwanted leaks!
you can purchase it from any auto place eg. repco, bursons, supercheat, etc
Appreciate the help guys.
You know, I gave the car a bit of a flog today, only for a couple of minutes, now I don't know if I have started to become used to the slight lack of power or if the power has gotten back up to what it was somehow.
you know that sensor that plugs into the cat? wot does that do? does it tell the car how much approprate flow it should have? I don't know, it just seemed to have a good strong burble session down this hill, then after that the power didn't seem to be as laggy and it feels abit more torquier from then on.
is this possible?
the other thing I am curious about. these cats flow at 570cfm or some unit of measurement. how much flow does a straight 3" pipe provide?
Adam
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
