97 87000km Series 2 RB25DET Gearbox and conversion parts, flywheel, 1/2 Drive Shaft ect $2000ono or Just Box $1500
Series II Interior in good condition (Seats, Door Trims) $350
R33 GTS-T S1 Non-ABS LSD $200
3" Front / Dump Pipe $150
Drivers side window Regulator $100
Complete Passanger side door complete less trim with small scrape. $200
Steering wheel- Series 2 Leather. Airbag not included Very good wheel $50
Some suspension parts.
Parts are in, Brisbane
Edited by Brokenz
Power Fc sold for $1250. I thought $1250 would be normal price for a used PowerFc as they are selling new at the moment on Ebay for $1540
Splitfire Coils Sold for $300
Decent priced pfc for both seller and buyer. PFCs should be coming down in price again, as they are once again available new. Limited stocks at the moment, but should increase again soon. Hopefully will have them available for brand new around the $900 mark again soon. Those were the days.
97 87000 Series 2 Engine with Std Turbo and loom $1650 (155-160 Compression, Splitfire Sparkplugs)
(Sold to Paul @ Option 1)
97 87000km Series 2 RB25DET Gearbox and front 1/2 of tailshaft if required $1500
Series 2 Nismo Copy white cluster with blue backlights 180kph 87000km $200
White Series 2 Bootlid and spoiler $150, White Series 2 Doors Less Trims, Regulators and Glass $250
Also have series 1 front and rear bar, rear windscreen, S2 ABS LSD Diff, and 1/4 glass and most other parts except for panels
u got pics of the cluster ?
Mate,
Any photos of the front pipe?
97 87000km Series 2 RB25DET Gearbox and conversion parts, flywheel, Std Clutch, 1/2 Drive Shaft ect $2000ono or Just Box $1500FIRM
Steering wheel- Series 2 Leather with airbag missing. Very good wheel $100
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
