was reading about afms and came across this
http://nissanskyline.6te.net/AFM.htm
so basicly what are my options if im chasing higher then 350rwkw?????
i thought about changing ecus so i dont have to put up with a afm, but are there any other options?
https://www.sau.com.au/forums/topic/206083-afm-dilemma/
  • Replies 44
yeah your thinking of the HKS vein pressure converter - its an inline remapper to let you use map sensors on an AFM style car
its only supported on the Z32 300zx so it wont work on rb25det neo etc, unless your up for custom hacking etc.
the q45 is a bit of a mixed bag, some claim over 400kw some claim they cant go past 250kw with it and the z32 works so much better
so not sure- its a mixed bag as i said. the problem with the q45 is that its 90mm so you have to change a ton of crap to test / use it
so if you try it and its poo youve just adapted all your pipe work etc to suit the 90mm only youll have to change it back to 80mm etc
i would try z32 in the cooler piping and see how that goes or even inside larger diameter piping
using larger diameter piping with the hot wire inside it can give it more resolution , but you need to be careful its not a backyard job
also if you max the afm at say 6500rpm then its OK its only when you max the AFM at say 4000rpm that its sucky
and even then, it will work just like a map sensor djetro style ECU, run along the horizontal load axis
https://www.sau.com.au/forums/topic/206083-afm-dilemma/#findComment-3646718
thats odd never realised the q45 was such a erratic performer i picked it up for 160bux with a plug on ebay so not to shabby
so what would your recommendations be paul???? should i test the q45 on the intake side or on the cooler side?
Edited by R34NRG
https://www.sau.com.au/forums/topic/206083-afm-dilemma/#findComment-3646723
yeah back 2 years ago 400rwkw was no problems on the q45 range
then all of a sudden we had a bunch of dudes who couldnt go past say 250kw
around that power level they would ceiling hit 5v and no more resolution
so not sure why or how - maybe a wrong batch of q45s or something - unsure
i dont think anyone on the forums has seen "official" proof of a q45 over 300rwkw
if it was me and my car i would go z32 relocated in the cooler piping
i dont think youll max it out and if you do it will be at some insignificant rpm
what turbo are you using ?
https://www.sau.com.au/forums/topic/206083-afm-dilemma/#findComment-3646735
who knows it might be one of those magical "400kw" q45's
until you try it - youll never know haha
ash ran a vanilla GT30 with z32 and went past 360kw and didnt max the z32 so you might be ok
hope so buddy, cuz u no.....my r34 is the best in australia it deserves the best HAHAHAHAHHAHAHAH
ill keep u guys posted
Edited by R34NRG
https://www.sau.com.au/forums/topic/206083-afm-dilemma/#findComment-3646768
Nice valentines day boys. But really, can we talk about some serious radiators. Not the group buy types. but some serious japan versions. Already checked out the trust versions but what else is there.
although i dunno where the hell u got radiators from, i need one aswell.......
https://www.sau.com.au/forums/topic/206083-afm-dilemma/#findComment-3646811
lol, that site never fails to crack me up.
1. It was created from information ripped from these very forums
2. The creator didnt do anywhere near the required research before putting some pretty factual information up (which is totally wrong)
ash's afm was in front of the turbo..
Yep :whistling:
Z32 - 370rwkw. AFM infront of the turbo, no issues at all.
A Q45 will register more airflow easily if its legit.
Others have done it before.
https://www.sau.com.au/forums/topic/206083-afm-dilemma/#findComment-3647123
That's my table :D I should have patented it
Yep :D
That creator may not have, but this one did, about 4 years ago and it was the best rule of thumb info around at the time.
That's good effort, better than I have ever achieved.
In the US I heard that Q40 AFM's are also 90 mm, maybe that's the problem
Me, just over 400 rwkw and Apexi around 1200 bhp with 2 x Q45's
Cheers
Gary
https://www.sau.com.au/forums/topic/206083-afm-dilemma/#findComment-3647863
Me, just over 400 rwkw and Apexi around 1200 bhp wiht 2 x Q45's
Cheers
Gary
hey gary
can you get us the serial # from this 400rwkw Q45
and also a photo if the label?
i think there could be two types of Q45's going around, one is poo and maxes around 250rwkw and the other is OK and goes past 400kw
https://www.sau.com.au/forums/topic/206083-afm-dilemma/#findComment-3647880
    • Just had this happen to me too.  R32 GTR.   Also broke "just before going out onto the track" - someone up there is looking out for us... Very scary since I was about to do a narrow street course with zero run-off and curbs everywhere. Many people on here upgrading to billet uprights and R35 bearings?   Or buying new OEM knuckles?  I am not keen to replace with another s/h 30 year old fatigued part.
    • Top off with distilled water and see what happens. If you keep losing coolant then you know to start looking.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
