was reading about afms and came across this
http://nissanskyline.6te.net/AFM.htm
so basicly what are my options if im chasing higher then 350rwkw?????
i thought about changing ecus so i dont have to put up with a afm, but are there any other options?
https://www.sau.com.au/forums/topic/206083-afm-dilemma/
  • Replies 44
yeah your thinking of the HKS vein pressure converter - its an inline remapper to let you use map sensors on an AFM style car
its only supported on the Z32 300zx so it wont work on rb25det neo etc, unless your up for custom hacking etc.
the q45 is a bit of a mixed bag, some claim over 400kw some claim they cant go past 250kw with it and the z32 works so much better
so not sure- its a mixed bag as i said. the problem with the q45 is that its 90mm so you have to change a ton of crap to test / use it
so if you try it and its poo youve just adapted all your pipe work etc to suit the 90mm only youll have to change it back to 80mm etc
i would try z32 in the cooler piping and see how that goes or even inside larger diameter piping
using larger diameter piping with the hot wire inside it can give it more resolution , but you need to be careful its not a backyard job
also if you max the afm at say 6500rpm then its OK its only when you max the AFM at say 4000rpm that its sucky
and even then, it will work just like a map sensor djetro style ECU, run along the horizontal load axis
https://www.sau.com.au/forums/topic/206083-afm-dilemma/#findComment-3646718
thats odd never realised the q45 was such a erratic performer i picked it up for 160bux with a plug on ebay so not to shabby
so what would your recommendations be paul???? should i test the q45 on the intake side or on the cooler side?
Edited by R34NRG
https://www.sau.com.au/forums/topic/206083-afm-dilemma/#findComment-3646723
yeah back 2 years ago 400rwkw was no problems on the q45 range
then all of a sudden we had a bunch of dudes who couldnt go past say 250kw
around that power level they would ceiling hit 5v and no more resolution
so not sure why or how - maybe a wrong batch of q45s or something - unsure
i dont think anyone on the forums has seen "official" proof of a q45 over 300rwkw
if it was me and my car i would go z32 relocated in the cooler piping
i dont think youll max it out and if you do it will be at some insignificant rpm
what turbo are you using ?
https://www.sau.com.au/forums/topic/206083-afm-dilemma/#findComment-3646735
who knows it might be one of those magical "400kw" q45's
until you try it - youll never know haha
ash ran a vanilla GT30 with z32 and went past 360kw and didnt max the z32 so you might be ok
hope so buddy, cuz u no.....my r34 is the best in australia it deserves the best HAHAHAHAHHAHAHAH
ill keep u guys posted
Edited by R34NRG
https://www.sau.com.au/forums/topic/206083-afm-dilemma/#findComment-3646768
Nice valentines day boys. But really, can we talk about some serious radiators. Not the group buy types. but some serious japan versions. Already checked out the trust versions but what else is there.
although i dunno where the hell u got radiators from, i need one aswell.......
https://www.sau.com.au/forums/topic/206083-afm-dilemma/#findComment-3646811
lol, that site never fails to crack me up.
1. It was created from information ripped from these very forums
2. The creator didnt do anywhere near the required research before putting some pretty factual information up (which is totally wrong)
ash's afm was in front of the turbo..
Yep :whistling:
Z32 - 370rwkw. AFM infront of the turbo, no issues at all.
A Q45 will register more airflow easily if its legit.
Others have done it before.
https://www.sau.com.au/forums/topic/206083-afm-dilemma/#findComment-3647123
That's my table :D I should have patented it
Yep :D
That creator may not have, but this one did, about 4 years ago and it was the best rule of thumb info around at the time.
That's good effort, better than I have ever achieved.
In the US I heard that Q40 AFM's are also 90 mm, maybe that's the problem
Me, just over 400 rwkw and Apexi around 1200 bhp with 2 x Q45's
Cheers
Gary
https://www.sau.com.au/forums/topic/206083-afm-dilemma/#findComment-3647863
Me, just over 400 rwkw and Apexi around 1200 bhp wiht 2 x Q45's
Cheers
Gary
hey gary
can you get us the serial # from this 400rwkw Q45
and also a photo if the label?
i think there could be two types of Q45's going around, one is poo and maxes around 250rwkw and the other is OK and goes past 400kw
https://www.sau.com.au/forums/topic/206083-afm-dilemma/#findComment-3647880
    • So, I started this repair and got as far as "fixing" the holes with some fibreglass. God all those years working on boats came back quickly. I decided I'd reach out to some rust guys just to see what they would say about it. I came across a guy about 40 mins away and went to see him. He said the windscreen needs to come out, that there might be some more bits around the windscreen and he'd quote them at the time. But his quote was $300 to remove and replace windscreen and $3k for the damage he can see. He said he could respray the roof for $1200 and the bonnet for another $800 (somebody has previously rattle canned it, its horrendous). This is $5300 + any small additional bits. It's a lot, I get that and the name of one of my fave youtube channels 'Not Economically Viable' comes to mind.  I'm not being financially rational, but I've taken him up on the quote. He's opening a new shop in November with more room, so we're waiting for that. I'll leave the currently missing headliner out until then. I'm looking forward to it being fixed and having the paint looking nice again (lots of clear coat issues on the roof too). / flame suit on.
    • Oh and some up-and-comings; New rear drivers wheel bearing. I'll do that this weekend while the diff is out. The car is already up and the d/c axles and missing exhaust will help with space. This is the last bearing for me to do and I've been dragging my feet on it. I also have some new EBC blue stuff pads for the car and some new brake fluid. I haven't ever flushed the fluid in this car and looking forward to it. I have 600 degree fluid to put in. Not exactly "race fluid" but better than the typical stuff I have been using.
    • A proper clutch/plate type mechanical diff with quite a lot of pre-load and high locking % is better for drifting. Much more consistent in its behaviour. A helical can be annoyingly vague and inconsistent in how it responds under the sorts of abuse found in drifting.
    • Some updates here. I pulled the entire interior out, minus some trim to respray the seats with Colourlock dye. It turned out really nice though I accidentally let the dog in the car after and she scratched up the front seat.  This is what it looked like before, the colour was just washing out everywhere but thankfully the leather was in good nic. Then after the respray   And after the bloody dog jumped in The headliner is out waiting to be retrimmed, but it will stay out now until Nov - see why below. I replaced the stereo/headunit with a period-styled Android headunit. I have no after pics, but I'll get some. This is because of the missing pixels. I tried to fix this twice with replacement ribbon cables but couldn't. Also the bluetooth interface I'd bought for this was crap. Then there's the rusty roof. Pics and info in this other thread. I have decided to get this repaired professionally, but I'll update that thread. This is why the headliner will stay out for now. I'll be getting the roof and bonnet resprayed at the same time the rust is fixed. I also had an interesting issue with my drivers door lock.  For a small period I was having issues getting any 12v power to the car - I mean *any*. It would have no dash lights, nothing. It happened while I was at the shops and I couldn't get in the car. So, we had 2 problems. The most pressing here is that I was locked out. I have only a single physical key hole on the car, the drivers door and no amount of turning would unlock the car. Surely it doesn't need power for this? The second issue is why am I losing all power periodically, The battery isn't dead, its almost like the battery isn't even there. Two issues that were surprisingly easy to fix. You fellow BMW over-engineering lovers will appreciate this. The lock in the door has 5 states; mechanical lock, electric lock, neutral, electric unlock, mechanical unlock achieved at -90 degrees, -45 degrees, 0 degrees, 45 degrees and 90 degrees. Although, the unlock is towards the front of the car, so opposite for LHD countries. Sticking the key in and turning 45 left or right is what is used 99% of the time. It activates the central locking etc. 90 degrees is for dead battery access and, obvs, only un/locks the one door. But because the mechanical lock is never used and is 27 years old, it seizes up. I was totally unable to turn the key far enough to get to the mechanical unlock (At the time of locking myself out, I didn't even know this was a thing). I eventually did it with some vicegrips and teflon spray.  I made a quick vid for other E39 peeps.   The battery issue is totally new to me also - It wasn't making sufficient contact between the post and the terminal. The terminal was bolted on tight, but the car wouldn't have power. After checking the battery with my multimeter I accidentally contacted the terminal and the battery post and the car got power. The battery was only a few years old and in good condition. I cleaned the post and the terminal with a wire brush, bolted it back on tight and never had the issue again. I'm still surprised that despite having solid contact it didn't work. Also, the car was getting Warragamba sized pools of water in the back when it rained. My initial concern was another rust problem. But when I went out on Weds while it was raining and while I had no headliner in I could see a steady stream of water coming through the roof mounted aerial. As this aerial is for the (now removed) car phone I pulled it out and whacked a blanking grommet in the hole. It seems fine now. I'm thinking I might get the hole permanently filled when the rust is fixed. Moving forward and things in progress; The tailgate needs some attention. I have taken all the trim off to clean it all and address some small rust spots. I have partially done all of this but I'll finish it up hopefully this weekend. As all the trim are now entirely devoid of trim clips I have bought a heap of strong velcro and I'm hoping it does a good enough job as any of this trim in good condition is super expensive and usually in Europe as we dont have many of the wagons here. Suspension and brakes!!! This is exciting. In the front; New control arms New sway bar links New lower Eibach springs (the only modification I'm planning on this car) M Sport shocks (these came with the car and will replace the longer shocks in the car) New top mounts Used 540i calipers (stock brakes suck!) New 540i disks and pads (22x296 mm for 528 and 30x334 mm for 540i) New front wheel bearings (thank all that is holy for bolt on bearings!) Annnnd in the back; New control arms New sway bar links Adjustable air suspension arms (fool the car into what the current height is so the self levelling suspension can match the new front ride height) New ball joints I'll also be doing a brake fluid flush while I'm in there. I'm planning on switching the car over to the 16's that came with it so I can clean up and respray the M Sport 17's. They've lost a lot of colour over the years and have some gutter rash. None of this will start until the E90 is back.
    • You mean you will regret it for drifting duties? I don't quite follow.
