Sambeh thanks bro pitty your not here to get loose!
Doof - loose pants without fail!
Jase - my sis birthday is on v day but she is like 8 yrs older than me! no mc lovin x2!
Jon - tis my birthday today, smokey is mc gay, ill be loose tonight, and give everyone a fright... tis my birthday today
James - party in the cross bro, feel free to come! no one will be home lol
Jess, thanks love, let us drive your white nugget!
Anna - tis good, nevarh breaks and always has traction lols!
Thanks billy mate - come out tonight if ya want!
Aaron thanks mate! hope the car is goood!
Im off to the pub for lunch with everyone from work!
LOOSE O CLOCK
ouch my head....
we made a new shot last night...
wild the sphincter of the universe, tequila, cetruce....
i called it the the sphincter of the universe LOOSE
wow i got everyone on them and we got LOOSE
Off to Goodvibes now!!!!
Love you all!
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
