hey guys, I have a mate with a spare rb26dett with a piston down in 1st.
Have just picked up a r34. Just wanting to know what can I take off the 26dett to put on the 25det? as in head/block? etc. etc.
I know the crank is possible. What else?
Cheers.
Edited by HKS_R34
https://www.sau.com.au/forums/topic/206138-rb25det-neo-rb26dett/
Where in my post did i say i can take the head off and wack it on the 25? I simply asked what is interchangeable.
I do not want to put the 26 in the car simply due to the fact i want to keep the 25det as it has very low km's.
Edited by HKS_R34
Well, since the heads are different, you can't interchange the parts (Intake & exhaust manifolds etc).
The block, I'm not too sure but the crank and rods can be used, not the pistons because RB26 pistons have a different gugen pin position.
Seriously, its not worth it. I'd rebuild the RB26 and complete swap the engines if you want the decent engine.
Pull your old engine out and sell it to pay for the changover.
But you mentioned the crank etc - you'd have to pull down the RB25 anyway to put it in?
Just because the odometer says it has low km's, doesn't mean they are. 90% of imports are wound back... And some I have seen as much as 50,000kms to 100,000kms. THink about it - THe car will be 10 years old, and most likely have 20,000 on it.. A normal driver does about 10,000 per year.
Edited by The Mafia
As the guys have already said you are not being specific enough about what is is you are trying to achieve. An example perhaps, the RB26 knock sensors will bolt onto the RB25DET Neo block. Is that useful to you? Probably not since the RB25DET Neo knock sensors are just as good (and possibly newer) than RB26 knock sensors. But maybe the knock sensors on your engine are stuffed, so the RB26 ones would be useful. The other bit of vital information that is missing is what model of RB26? For example an R34GTR exhaust camshaft will fit an RB25DET NEO, but an R32/33GTR exhaust camshaft won't, because the CAS drive is different. Oil pump, an R32GTR oil pump is not worth swapping to, but an R33GTR S2 and R34GTR oil pumps are definitely worth it.
Not so simple is it? So please supply some more info and we will see what we can do.
Cheers
Gary
Cheers
Gary
Thanks this is the sort of information i was looking for. It is an r33 rb26dett,
As for the kms. Well compression come back 150 across all boards. So im happy that it is a relatively safe base to work with.
Edited by HKS_R34
Cheers
Gary
hi,
sorry for correcting you SK, but afaik rb26 knock sensors are quite different from rb25.
    • Yep, it was only an option on the Q50 Hybrid.  Same in Japan as far as I know. And doesn't use a centre diff like the Suby's do, so not the same as the WRX.  But it also isn't a reactive AWD like other Nissan AWD vehicles are, eg. Murano/Xtrail/etc.
    • You should have got a Maine Coone then. Only thing is they're big. But so cool, and just like a dog. Or, just get yourself a high performance dog. That'll teach you for wanting Parkour indoors 😛
    • Are you thinking of Bens R32? I don't remember if his went through the bonnet itself, but it went through the chassis rail. Brad (RISKIN) bought it, and turned it into a track car. It's funny how anti people are of Jim Berry now. I remember when I pulled mine out (during an engine change) and inspected it and found it cracking badly. At that point in time so many people were even on SAU, were so pro Jim Berry, and that was after Bens GTR exploded his quite publically.
    • That's one of the reasons I got that breed, they look weird, the other reasons are they small, they are very vocal, and run around like they are on crack, I didn't want a breed that just sits around, these two are like kids on red cordial  My daughter has one, and it's a laugh riot, constantly doing Parkour around the house, sits on her shoulder, plays catch, and constantly runs around the house taking turns chasing the dog around, her Bermese though, just lays around with constant bitch face, and just looks on in utter disgust at the cat and dog playing together
    • I'm getting PTSD flashbacks seeing that name again.  With my turbo swift, I got 1,500km of street use on a Jim Berry clutch before it exploded and took out my input shaft with it.
