  • Replies 132
well, I'm not the title holder anymore ;)
but this is what I'm doing.
In beginner mode, the last championship, there is a laguna seca race. enter that one. its only 2 laps and the first wont be quick due to traffic, standing start etc.
However, there is no tyre wear in beginner. So you can do the race with super-soft cheater tyres front and back.
That should help heaps.
hmmm ok boys..
buy cheater tyres.. install them..
go to run and settings choose luguna seca..
no tyre wear.. u get a ghost to chase if that turns u on... and its easy to go in and out to do changes to ure car...
i nailed a high 1:09 last night.. but i believe should be abel to get 1:07's around there.. just hard to nail a perfect lap.. this track is shit :)
OK... I'm down to 1:20.something... still using the street GTR (still too poor to afford a pennzoil one... yet) I have all mods except the touque split controller and am still using a stage 2 turbo... was thinking of going the stage 4 but for 80,000 cr I thought that I would save this towards the Penz GTR!
Funny thing was that I improved 7 seconds with the cheater tyres and no extra mods... add bigger turbo and spension and all the other stuff and improve 5 seconds...
Ok... so what is the next challenge toshi... I think hat by the time I save enough creds and then buy me a penz GTR and then learn to drive it around Laguna Seca this challenge will be over and I still won't have made that time!
Dan.
    • And one last super random thought, I remember when SAUNSW had a dinner with Alan Heaphy, and another with Fred Gibson there was talk of the R32 GTR cast alloy uprights failing in racing, and one of the things Fred did when they had to add weight to the vehicle was taken the failing alloy uprights, and have them made of steel. Does anyone remember back to 1990/1991/1992 and WHAT was failing in the front hubs/uprights?
    • If you truly want to know how the original failed though, was it a factory defect possibly etc, send it off for investigation. Would probably cost a shit tonne.   The ones that you need to win lotto for, unless you have a good reason for that part to be bolt on, I'd probably roll with getting a few small stitch welds carefully put in place as an extra safety factor once everything is all torqued up tight
    • Are you sure? Because I wouldn't necessarily be. Do we even know the material they've made the new uprights from?   Looking at the fractures in the earlier pics, it does to me look like both a twisting, and levering upward action doing the damage, so you're hoping for both compression, and tension. Depending on the bolts, they can stretch (even high grade bolts will) and now you're hoping for the threads themself not to stretch, as if they do, bye bye mating surfaces holding together, hello bolts now going into shear.
    • Lets say I wanted to buy this, specifically for this purpose. How do I actually perform the function. Can I still buy a Consult-1? Am I about to be burned by the fact my car is a 2000 model Series 2 R34 and thus will be some stupid other system? Do I just need this -> https://obd2australia.com.au/product/nissan-consult-14-pin-to-usb-ddl-diagnostic-interface-with-ftdi-ft232r-chip/ And with what software?
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
