depends on how it is supposed to be pronouced. if it is supposed to be pronouced the same as the constelation (oh-ryan) then it is ok as it is completely different.
but then toyota has the ascent (assent) and hyundai has the accent (ack-sent)
  • Replies 115
Posted Images
orion.... what a name meh??
You reckon? I can't really see a market for a diesel Falcon. Territory yes, but not so much the Foulcan. Maybe if they continue to be similar it will be easy to bung an oiler in both.
well actually I do see a market here for Diesel.Europeans have been using the stuff for years.In fact the Majority of cars sold there are Diesels.Both Ford and Holden had better realise whats going on in the world.Diesel is only going to get bigger. The way fuel prices are going large engined sedans on petrol will be completely unaffordable very soon.Diesels use so much less and with the technological advances Diesels have made these days accelerate as good and better than the Petrol engine equivalent. Look at what VW has done? their Diesel cars are quicker than the same car with the petrol engine..Howabout Audi winning Le Mans in a Diesel?
Yes the euros have been driving diesel cars for yers. But then again if fuel was double the price, the roads half the size & the taxation rates even more stupid than they presently are everyone here would probably be driving a 1 litre diesel Fiat something. And hating it. Not sure if you noticed but diesel prices are in lock step with petrol prices - and it is more expensive & less common (in metro areas). Plus you have to stand in the awful black oil slick & get the stinking sh!t all over your hands every time you fill up. Then there is the noise, the lack of a torque band more than 2000rpm wide, the dodgy resale....
Audi winning Le Mans. That is mostly about weak opposition & stupid rules. Like Le Mans has always been, really.
In any case given that Australia has an abundance of gas it makes sense for Ford to build an engine that runs on LPG. Which they do. So maybe less of the is Euro is good and a little more credence to the local engineers who are building the things.
Edited by djr81
:D he's not the one on drugs funky! VE looks like crap! :D
I really like it, does look similar to the BF's in some parts but that's ok, you don't have to go overboard and make a new model look totally different, especially when the BF was such a hit.
Agreed - this new model shits over the VE in the looks department, probably in every other way as well.
On another note, once the V6 has been integrated on the falcons from 2010 onward, guess what the XR6T or G6E Turbo will be having? Yupp.. you guessed it, a twin turbo V6 :D
It will be the same engine from Lincoln MKS that will commence production around 2009.
The V6 Twin Turbo is called " Twin Force "
TwinForce / EcoBoost
A direct-injected, twin-turbocharged version of the all-aluminum Duratec 35 has been developed, producing 430 hp (321 kW) and 400 lb·ft (542 N·m) of torque. The TwinForce 3.5L V6 is intended to deliver the performance (on demand) of a typical large displacement 6.0 L-class V8, with the normal driving (highway) fuel efficiency of a 3.0 L to 4.0 L class V6.[4][5] The engine is also capable of operating on any mix of E85 ethanol and premium gasoline, and made its debut in the Lincoln MKR concept coupe/sedan, introduced at the 2007 North American International Auto Show.
Gasoline direct injection more precisely manages fuel flow into the cylinders, for more efficient combustion and emissions control, when compared to port injection. Twin-turbocharging forces more air into the engine on demand, allowing additional fuel to be injected and burned, producing more power: 118 hp (88 kW) per liter in the case of the TwinForce. Technologies for the twin turbocharging system were developed in cooperation with Volvo Cars, and the gasoline direct injection system is a joint development between Ford and Bosch based on Bosch DFI systems already in production.
At the 2008 NAIAS, Ford introduced a similar gasoline turbocharged direct injected engine family called EcoBoost, scheduled for production starting in 2009.[6] The EcoBoost family is expected to be available as four-cylinder I4 and six-cylinder V6 versions. The 2010 Lincoln MKS is scheduled to kick off EcoBoost production, with a 3.5L V6 version estimated at 340 hp, in mid-2009. The Ford Explorer America and Lincoln MKT concept crossover utility vehicles, which debuted in the 2008 NAIAS, show a similar displacement GTDI EcoBoost engine with up to an an estimated 415 hp.[7] The company eventually plans to equip a half-million cars and trucks annually with turbocharged EcoBoost engines by 2013.
Edited by Barbarian
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
