***MORE PRICE DROPS ***
***UPDATED Mon 7th APRIL***
Item: Various bits and pieces left over clogging my garage!! See pics and extra info
Item Condition: Second hand - good condition
Reason for Selling: Parts not needed
Price and Payment Conditions: See Below
Extra Info: Prefer Adelaide buyers / pickup. Able to ship at buyers cost. So many parts don't want to spend ages chasing up freight costs etc.
RB20DET / R32 GTST Type M Parts
RB20DET Std Front pipe $25
Factory driving lights to suit Type M Front Bar$25
Std Stereo $15
Std Dump pipe $20
R32 Type M Front rotors $20 (29.5mm)
R32 Std Fuel Pump $40 (was ok - replaced with r33 GTR pump)
RB25DET Parts
RB25DET Alternator $50
Brackets for ancillaries etc $10
RB25DET Air con compress $50
RB25DET Starter Motor $50
RB25DET Airbox with filter $40
RB26DETT / R32 GTR Parts
R32 GTR Std clutch line $40
R32 GTR Gun Metal Grey std bonnet with nismo splitter and battery triangle $600
Std GTR turbos x 2 minimal shaft play $550
Std GTR dump pipes x 4 $25 each
GTR Trust MX front pipe $250
GTR Jap tuned length front pipe $300
R34 RB26DETT std cams and cam gears $250
R34 GTR Valve Springs $100
R32 GTR AFM x 2 - Excellent condition, upgraded to PWR FC D-jetro so not needed - $200
Misc
Alloy Swirl Pot $50
Kenwood Jap Tape head unit / 12 stacker with remote $50
Greddy Turbo timer $40
17 inch tyresx2 good for drift $20
Pioneer 7 inch Pioneer AVH-P7500 II In Dash DVD / CD / TV (incl TV tuner box and aerials) $1000
Custom Sub box for 2x12inch subs to fit R32 with rear strut brace $100
That’s all I have folks - so don't ask for anything else!! Seriously this stuff is just clogging my garage - no reasonable offer refused (I’ll probably even accept some unreasonable offers - try me!) All proceeds going towards the "Save the GTR - make it faster" fund - go on be a part of it! First in with the cash gets the goods 
Contact Details: PM me, Email me at [email protected], or 0439 703 239
Cheers,
Andrew
Edited by Blue32
  • Replies 47
More Pics including APEXI 50mm alloy radiator for R32 / GTR suit Repair / Recore - $100
Edited by Blue32
More pics
CeJay - Fan has no cracks, got it with the RB25 I put in my previous ride (R32 GTST). Delivery to Canberra $20.
Edited by Blue32
Interested in the front bar, where abouts in adelaide are you located?
I'm in the Alberton / Cheltenham area (City side of Pt Adelaide)
can we organise a time so i can come inspect?
Sometime during the week would be great, anytime after 6 is good for me.
So how many k's has the water pump done since the 100k replacement?? interested.
This pump is the one I replaced at 100Ks, and I was told it was changed before I bought the car. I changed it again to be sure, so this one has possibly done between 20 and 40 thousand? Best guess anyway, its in good nick and didn't leak.
Front Bar SOLD thanks Simon-R32
PWR Steer pump / Brackets / Eng mounts and RB26 EXH manifolds SOLD PENDING PAYMENT / PICKUP
PWR STEER PUMP + BRACKETS, ENG MOUNTS, RB26 EXH MANIFOLDS SOLD thanks Craig
Edited by Blue32
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
