hi guys,
I recently have spun a big end bearing and i just want to know how to help prevent it from happening again.
These were the mods when it happened:-
ACL race bearings
N1 oil pump
blueprinted bottom end
Castrol 5w-30
Is there anything i should do or is it just bad luck/motor not put together probably
cheers Tom
https://www.sau.com.au/forums/topic/206613-r33-gtr/
  • Replies 49
Getting a baffled sump will only help with keeping your oil cooler (but upgrading to an aftermarket sump will generally mean higher capacity which is a good thing) and your problem has stemmed from lack of oil.
The simple fix is to overfill your oil 500ml - 1L above the full marker but this is generally just a precaution for track going vehicles.
considering your car is street only id be wondering if there was some sort of blockage or your oil pump failure. This really shouldn't occur on a street only car.
https://www.sau.com.au/forums/topic/206613-r33-gtr/#findComment-3655137
Sorry, but you have missed the point of having a baffled sump - The point of the baffles isn't to keep your oil cooler, but rather to prevent oil starvation under hard cornering/load, which is particularly common at the track.
Ideally, anyone building an engine should be at a minimum fitting sump baffles, a good quality oil cooler, and an upper oil gallery restrictor.
https://www.sau.com.au/forums/topic/206613-r33-gtr/#findComment-3655278
what oil should i be using to help prevent this happening again??? also would keeping the oil cooler help. what temperature should it be at??
Yes, keeping the oil cool is a priority.
Which oil you choose depends on your engine and its condition.
If the oil gets too hot, it gets too thin and you will run the risk of spinning a bearing again.
Personally I run Motul 300V Chrono, however given that my GTR takes 10 litres per change with my larger sump and cooler setup, it makes for expensive oil changes!
An oil cooler really is a must have on a modified GTR.
https://www.sau.com.au/forums/topic/206613-r33-gtr/#findComment-3655326
IMO - Baffles - waste of money as its only fixing another problem indirectly.
For a street GTR, with the RIGHT head modifications to stop the oil starvation in the first place... negates the need for a sump.
Heavily tracked GTR's here (350rwkw style) ran stock sumps without problem, so can you for a street car :)
Read the FI Guide (its a sticky), and in there it contains a link for Oil Control in RB's.
If you get that right, and have it rebuilt correctly, there is no reason it should die.
I would say your motor either wasn't assembled correctly or you ran low on oil at some point possibly. Likely bet is motor assembly.
Castrol 10/60 is what i would be using in a built motor personally, been run in all of mine for the past 4 years, no issues
5/30 is probably part of the issue
https://www.sau.com.au/forums/topic/206613-r33-gtr/#findComment-3655372
what power are you putting out?? what rods are you using? what rod bolts/studs are you using??
pushing big hp on stock rod bolts "can" stretch and lead to big end failures, although oil control problem are common in gtr's as stated
A spun bigend on a 20k km built engine driven on the street = something very very wrong
https://www.sau.com.au/forums/topic/206613-r33-gtr/#findComment-3655410
Detonation/pre-ignition is probably the biggest killer of conrod bearings on GTR's when the boost is wound up. Most of the time you'll find there's no oil pump problem etc.. Have a look at the other conrod bearings, if they have marking on the upper bearing from 10 thru 1 o-clock it's usually a good sign of detonation. It happens because the mixture fires too early and the piston is pushed back down the bore while the crank is still trying to push it up, this squeezes out the oil film and you have metal on metal contact between the crank journal and the bearing.
https://www.sau.com.au/forums/topic/206613-r33-gtr/#findComment-3655710
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
