Engine:
O-Ringed, Line bored, Bored to 87mm and torque plate honed block
N1 Water Pump
Arias 87mm Forged Pistons
87mm N1 piston rings
Argo Billett Conrods
Genuine R33 GTR Crank
N1 NDC bearings
Complete bottom end balance (Clutch/flywheel, rods, pistons and crank)
ARP Main Stud Kit
ARP Rod Bolts
ARP Head Studs
Tomei Cam Studs
Trust Sump Extension, baffle and pickup
Jun Oil Pump
Jun 272 10.5mm IN & EXT Cams
Tomei Adjustable cam gears
Jun Valve Phosphor Bronze Guides
Jun Valve Springs
Precision valve shims
Head fully serviced and machined to accept cams
Nismo Engine mounts
HKS 1.6mm Full head gasket kit
Garrett T04Z 0.84 Split Pulse Turbo with ceramic coated rear housing
6-Boost steam pipe manifold (split pulse) ceramic coated
Tial 44mm Wastegate
Braided Oil and Water turbo lines
Sard Fuel Pressure Regulator
Sard 800cc Injectors
Bosch 044 pump mounted internally
600x300x120mm Intercooler
Trust Type-R Blow off Valve
HKS Hard pipe kit
K&N 9 inch air filter
Blitz SBC ID-III Boost Controller
Apexi Power FC D-Jetro with Hand controller
Yashio Factory Triple core radiator
Greddy Air Diversion Plate
3” Front pipe heat wrapped
Decat pipe
Apexi N1 90mm Cat back
OS Giken Triple Plate Clutch
Essential Oil Catch Can
Nismo Short Shifter
Suspension:
Tein HA Coilovers
Nismo Front strut brace with Brake Cylinder stopper
RSR Rear strut brace
Whiteline Subframe alignment kit
Whiteline front camber kit
Whiteline rear camber kit
Whiteline castor kit
Buddy Club Hyper Gold P1 Racing Wheels with near new 235/45/17 Nankangs all round
Hicas Lock bar with Lines and solenoid completely removed.
Exterior:
N1 Nostrils
N1 Side Skirts
Carbon Fibre N1 Bonnet Lip
Carbon Fibre N1 Boot Lip
Trust rear pods
Ganador Mirrors
6000k HID Kit
White LED Park lights
Interior:
Impul 300km/hr speedo
2wd/4wd Switch
Apexi Power FC Hand Controller
Blitx SBC ID-III Boost Controller
Apexi Turbo Timber
Autowatch Cat-4 Alarm
Defi BF Oil Pressure
Defi BF Boost
Defi Link Controller
Pioneer MP3/CD Head Unit
Pioneer 3-way Front
Pioneer 2-way Rear
Momo Race Steering Wheel
New leather gear and handbrake boots
Car is in immaculate condition, boot holes have been removed and boot lock shaved professionally. Motor was built less than 4000km's ago and has not missed a beat since then, only had BP98 in the tank and Mobil 1 changed every 1000km's. Ant Scali from X-Speed tuned to 430rwkw/575rwhp on 24psi with no cam timing changed and conservative timing/fuel maps.
Overall it's a seriously quick car for street, drags or track. I have built this car over the last 2 years to be the best it can be, engine is super responsive for the power and gets over 1 bar of boost before 3800rpm in 4th gear and pulls smooth all the way to 8500rpm.
Looking for offers around $38, 000
Any more info needed, please dont hesitate to ask via PM or 0422426866
Cheers
Simon
Edited by Cerbera
https://www.sau.com.au/forums/topic/206647-r32-gtr-430rwkw575rwhp-immaculate/
sorry no 1/4 times as i have not run it at the drags...
pics were taken at motovation 2008, a non drag racing event at the kwinana motorplex
Edited by Cerbera
  • 1 month later...
  • 2 months later...
  • 4 weeks later...
  • 3 weeks later...
