Hey, am after a new fuel pump..just wondering wat i should get??
common one i hear about is the bosch 040/044/023..
so wat is the ext. difference between the 3??
and which one is going to last?supply enough fuel etc..worth its valve..
or should i be looking at a nismo/walbro pump??
https://www.sau.com.au/forums/topic/206666-r33-fuel-pump/
The bosch 040 is a intake pump
The bosch 044 is a bigger version than the 040 but is an external type pump
The bosch 023 is pretty much the same as the 044 but the intake style (ie it has a open base for the pickup on the pump)
Personally i would stay away from walbro and just get a bosch (i have fitted a 023 to my bros car and works a treat), if you want to spend more on a direct replacement then get something along the lines of a nismo pump.
A bosch 023 will well and truely get you your 350rwhp
Edited by R34GTFOUR
https://www.sau.com.au/forums/topic/206666-r33-fuel-pump/#findComment-3655458
so the 023..is that internal??
sounds good..
but can i simply attach it to the cradle etc..
of do u gotta modify it heaps to make it fit??
so is the 023 a bigger fuel pump than the 044?
Edited by bumble_bee
https://www.sau.com.au/forums/topic/206666-r33-fuel-pump/#findComment-3664683
Bosch 023 = Nismo pump... unsure if it plugs straight into position, or needs modificaqtion to fit (doing my research atm lol)
023 Flows 168 L/hr @ 5 bar (internal) L=169mm D=60mm
040 Flows 102 L/hr @ 6.5 bar (internal) L=169mm D=60mm
044 Flows 200 L/hr @ 5 bar (external) L=196mm D=60mm
Bosch pdf comparison fuelpumps.pdf
Bosch fuel pump website: http://www.bosch.com.au/content/language1/html/4560.htm
Hope all that helps :thumbsup:
Edited by infamous_t
https://www.sau.com.au/forums/topic/206666-r33-fuel-pump/#findComment-3683089
R34GTFOUR (see for sale thread) has a second hand 023 on R33 Bracket in Perth - buy? (edit)
If you're only after 350rwhp the simplest/cheapest would be a GTR pump (drop straight in).
or Antimatter (see for sale thread) had a second hand Tomei for sale that is the 276 l/hr drop in upgrade.
At 350 rwhp a 040 will be enough but needs a bit of fiddling about as does the 023 which will give you 276 l/hr (heaps)
$ vs stuff around.
Or go 044 with surge pot and pick up the advantages of a swirl pot and heaps of delivery but more $
Edited by WRRR
https://www.sau.com.au/forums/topic/206666-r33-fuel-pump/#findComment-3684087
The GTR pump is good but saying it is a drop straight in, is not quite right
THere's a bit of fiddling and choping and if you're not confident, you'll give up...or if you do get it in, you might get some noise from hitting the tank if you were a bit off.
But then, again, this applies to any of the Bosches too.
I'm not trying to paint a bad picture on the them, they're all good options but the only Drop In option is a Tomei or Nismo
Absolutely no fabrication needed whatsoever.
Evrything required is in the pack.
....and, apparently Walbros aren't up to the task, which gets mentioned quite alot and peeps still buy em cause they're cheap....
(i think their flow rates are true on a different amp/voltage of something...maybe 14volts? where the Nissan is 12volts?)
https://www.sau.com.au/forums/topic/206666-r33-fuel-pump/#findComment-3685597
  • 3 weeks later...
so with the tomei and nismo and gtr pumps..
are they a direct replacement of the stock pump..
lik can i just simply pull out the old stock cradle and drop the new one in...?
or do i got take the pump off and put the new one on..
but no modifications to cradle, lines etc.. is that correct???
unlike the 023 wer i have to modify..
i heard about changin the stock wiring too..is this also required wen fitting a new pump?
https://www.sau.com.au/forums/topic/206666-r33-fuel-pump/#findComment-3738422
genuine Walbro pumps are fine.
genuine bosch pumps are fine
i have fitted a couple of walbro's and a 040, when they are wired right they are good.
you can pick up a 040 for $190ish off ebay, couple of 2.5" hose clamps holding it in the stock cradle and cut the earth after the plug on the tank lid cover and wire/earth it to the body and you'll be set.
that will be fine till the power bug returns then it will serve as a lift pump ready for a surge and 044 inline :D
https://www.sau.com.au/forums/topic/206666-r33-fuel-pump/#findComment-3738436
hey mate
i've just recently gone down this path.
i tried with an r32 GTR pump to put it into my r33 GTST...... lot of fiddling and i didnt get there (dunno if the r33 pumps are the same). I reckon if i had more time i could of got it to slide in.
Anyway i ended up buying the tomei fuel pump (comes complete with cradle thingy), this just comes straight out of the packet/box and slides straight into the factory guides. Tomei from what i hear is EXACTLY same as nismo.
Answer is: TOMEI/NISMO are direct replacement
Anything else requires fidling.....that's what i am able to put together (havent tried them all like all the bosch's....)
on the topic i've found that my tomei gives a slight hum in the cabin...its only very very slight....and i still like it. and then when you step on the peddle the hum steps up a pitch....kind of cool......but the sound is only just noticeable.
Thats another reason why i went tomei as with the other ones needing modifying you gotta be certain the pumps not lieing on the fuel tank wall -----> your "hum" becomes a "buz".
But price wise the tomei/nismo is a a bit more expensive than the others.....so comes down to your call.
https://www.sau.com.au/forums/topic/206666-r33-fuel-pump/#findComment-3738447
so do u get the upgraded wiring with the tomei pumps..lik do u got re-wire the new tomei pump..or do u get a harness that plugs straight-in??
so far that looks like the tomei pump is better pump to choose...
i heard of alot of people had to re-wire their car fuel pump wiring..well thats wat ive bein told by mates..
some reckon u dont have too..but yeah...coz of the voltage required by the new pump..some evan using relays..
is this required aswel???
(sorry if someone has already asked these questions)
https://www.sau.com.au/forums/topic/206666-r33-fuel-pump/#findComment-3740920
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
