Motorplex meet.
  • Replies 233
That "one sweet camera" is a Canon IxusV, that was on 1024x768xFine
It can do 1600x1200xSuperFine too.... but then i only get 80 shots of it.
I'll stick with 130shots of 1024x768
I got a few video's (yes, with sound) I may post up, but the resolution was down 160x120.... (could have had 640x480) so u can't even recognise the cars running.. they were skylines tho...
damn that was a good day.. 14 runs in total.
best of 14.66 with a full exhaust system.
all where pretty consistant with one another, if my 60footer was XX secs off my best, it was XX secs off the final time too.
would everyone be up for another once the wednesday nights start again. it'd be alot cooler.
techone ive seen run a 11.4 or was it 5.. anywho, it was quick :P
I think I have a video of it somewhere.
Shaun
Well that was a good first run of all time:p
I gotta admit im pretty happy with 14.38 as not much has been done. I reckon i coulda got it down a bit but i was a bit stressed about the whole axle hop thingy. Come to the conclusion that my suspension is not too good for drags.
Good to see most you guys down there even though i missed a few of you im sure ill catch up at the next event.
BTW: when is the next event?
Cheers
Shaun:D
14 odd skylines on show!
Damn I am unlucky sometimes:(
Oh well I'll just have to wait for a mid week event so I can go too.
That mid 13 of 'buffy's (may she rest in peace) is still looking a fair way off for our GTST boys.
Who will be first to take the glory?
Originally posted by skyzerr33
but rev210
buffy's record is for stock turbo cars?
Killer-T and Macka don't qualify anymore as they have after market turbos hehe.
atm Grandenko has the best stock turbo run at 13.80 which is fairly close to buffy's 13.65.
Grandenko can have the title for stock turbo/ stock ecu/ stock ic, then.:P
I did a quick search on SDU and found Buffy ran a best ET of 13.71@169kph, although highest TS was 13.9@175kph. Both those runs had a 60' of 2.279. These numbers are from the orginal drag meet thread, where Chris ran Buffy for the last time (AFAIK). Its interesting reading through the archives and seeing Buffys quoted ET get lower and lower as the date gets further from the drag meet :)
Buffy had:
HKS Intercooler
3" exhaust
13psi boost
Apexi Power FC.
I'm not sure I qualify for stock turbo/stock ic/stock ecu title, as the s-afc could be counted as a piggyback device. I'll gladly take the stock turbo/stock ic title tho :P
And I'll be back for the wed night drags with a fmic to battle for Buffys title too :)
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
