Hey guys, im wanting to know whats a good reading for a compression test on an rb26 engine, i just got a new motor put in, and would like to make sure its going to be healthy for me.
Basically the guy i bought it off advised me the readings he got before giving the motor to me were:
165.7
165.8
167.3
170.2
165.1
165.4
Is this a healthy motor?, and i want to do a leakdown just to make sure....
How much will it cost to get a compression test done, and wet/dry leakdown test???
Thanks.
thats pretty good, maybe even a little bit high for a RB26.
My RB25 was 165psi across all 6, and its compression ratio is 9:1.
THe RB26 comp ratio is lower so you would expect lower compression test results.
As long as they are all equal or within 5% mate.
Cranking compression has alot more variables than just compression ratio.
165.7
165.8
167.3
170.2
165.1
165.4
OMG! Nah mate thats terrible, its going to let go soon - take it back and say you changed your mind
Im kidding, do a search on comp tests and you will see those numbers are fine. Now go get the keys, take it to a track, and make it earn its keep!
Personally I like the mathematical precision at which the tests were performed. 165.7 on cylinder 1 are you sure it wasn't 165.732 psi?
I'd be doing my own test as those firgures sound like he's pulled them out of his arse.
Edited by rob82
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
