yeah that will be your problem then - open the bleeder, start her up, run until thermostat opens you will get steam and later coolant out of the bleeder. Once its mostly coolant do the bolt back up.
tried the bleeding, no luck, still getting hot, seems to be getting hot still - could the radiator have been clogged with crap after the headgasket blew?, im getting it flow tested and clean to make sure its all good, as when we did remove the radiator, we did knock the fan assembly on it by accident ever so slightly....
Regards,
Nainesh
Tried all that and still no luck, radiator is fine!, im hoping its not internal now...While on the subject, i noticed, as soon as that heater went on, the temp rose much faster, whats normal on the gtr???, it was half way on the guage, then its starts to raise...so engine goes off!
Edited by nsta
Helps if you have a powerFC - you can see the exact temperature on the hand controller. The stock temp gauge should sit at half way or a touch under, as soon as it gets above that, its to hot.
Maybe the gauge sender is different between the two motors, do you still have the original one around. Its the single wire sensor on the inlet manifold near the injectors, should have a blue with black trace wire attached to it.
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
