gosh is that the veilside supra wing?!??!?!
no offence buddy i commend u for the way u have expressed yourself but its just wrong.
get rid of the wing at LEAST
hahaha yea ive been wanting to get my boot flush mounted with the spoiler removed
  • Replies 60
If you got rid of the red in the middle of the light,... then you would end up with brake lights that look like huge reverse lights!
It's the same as fitting clear indicators, you have to fit an amber bulb, or else you would have flashing reverse lights.
Brake lights must be red,... indicators must be amber, reverse lights clear... it's universal,... although some American cars have red indicators mixed with their brake lights, which is kind of off putting.
good point couldnt have put it beta
Dont like em that much. sorry, but thats my opinion. Maybe if u painted the insides red? But that'd get rid of the reflectiveness and make the lights useless. What would tinted lights look like?
ive seen a r34 with tinted clear tail lights looked very
nice
That's like taking a reputable import,... and deliberately turner it into a ricer!
You would get more recognition taking it back to stock.
However,.... you are from New Zealand,... so maybe that explains why everything's so backwards.. ;)
well let me tell you this buddy... some people modify there car to its full extent body and all. reffering it to stock is very boring especially since skylines are everywhere!! and to put it out there i read hot4s (auz) and i read Performance car (nz) magz. there are always cars in hot4s with what you would call 'rice' take a look at nz magz most go for power and ignore bodykits...and backwards???? :thumbsup:
yo
isnt that something u wud catch if you raped people :thumbsup:
Whilst there is a probability that you can contract STD from raping people,
there is still a chance you won't catch anything at all,
whereas that car and any occupant of that car stood no chance.
That is your choice though. Personally, I think HOT4s is the best mag on the stands, which is why I have over 50 copies. If waza thinks they look good, let him think that. You have given your opinion on them, let everyone else give theirs. No point having a go at them for taste, mate.
HOT4's is definitly a good mag ive had to throw some out coz i
had to many lol it does contain alot of riced cars tho but there is nothing wrong with that
hahaha if you say so mate :)
Edited by waza
issue 90 of HPI the pink 33 drag car looks pretty good. the rear lights suit it well... dont know about the LED chromey plastic tacky look of the one you can get off ebay ect... ghey!
oh, and hot 4 is terrible, HPI FTW!!
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
