Hey all
My 32 GTR has tein suspension in it. I am the first owner in aus and have had it for about a month.
This is the car's only mod and i suspect it is jap spec suspension with a really hard spring rate
The car is soo stiff to drive :banana: , i have softened up the fronts to as far anti clockwise (softest), and i cant yet get to the rear.
So
what i ultimately want is a suspension set up that is going to give a smooth ride over handling.
Not to say i want to feel like im driving a boat, but what i have now yea probably gives great handling, but i need to use the car every day
so i want something thats going to be comfortable.
What do you think my options would be :banana:
I was thinking about selling my tein suspension and maybe just puttin in stock GTR suspension, or possibly a new setup of some kind.
Also, how do i access the rear shocks, do i have to pull the seat out. How do i do this?? Can anyone tell me the steps
Thanks heaps guys
This is really driving me mad! :dry:
cheers
:spam:
Yeah you probably only have 2 options; harden up or just swap em for something else.
If you decide you want stockies, I have a set in perfect working order in Melb, so PM me if you want em.
Before pulling the seat out, check behind the wheel, some shocks have their adjustment knob there.
What type of teins are we talking about here? Assuming they are not super streets as they are relatively soft as far as coilovers go.
Depending on what they are you could modify your existing set-up. Could end up costing $$$ though.
Or you could buy my super streets (see for sale section) and make your money back by selling your existing ones off to someone who wants to do circuit work.
Going back to stock seems a bit backwards to me.
Edited by taynewguy
i managed to get into the boot and turn them soft at the back
antu clockwise (to the left) yeah???
so ill see if its better
ill take it out for a spin
think the teins are HA
if they are in top nick...not leaking or squeaking $800-900 is a fair asking price.
Ive got HA's and the first week i couldnt drive for more than 20mins before i got a sore neck. I hardend the F up and now my necks the same width as my head.
yep SK seems to be good and proven for comfort and performance.
Just get them revalved with some different springs. I have the sk setup on my gtr and if you have your car lower than std you lose damper travel and will hit bump stops all the time. the bilsteins are awesome, however they are the same length, if not larger than std shocks. The jap coilovers have an actual shorter shockbody and are designed for max shock travel at lower ride heights.
Talk to cenerline suspension or racepace.
    • I hope it's actually possible. This is a write off in insurance world.
    • Yup. 2-way with shallow ramp angles. Still works.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
