Here are the specs!
Engine: VQ32DETT V6 Twin-Turbo with DIRECT INJECTION! (in colaboration with Cosworth!!!)
Power: 480ps (352kw!) @ 7200rpm
Torque: 58kg/m @ 4800rpm (don't know the conversion...)
Turbos: No confirmation on the size, although it's probably a couple of T-28 sized units. Get this: They have incorporated a
motor-assisted spool-up!!! Yes, no lag here!!! The death of the Supercharger maybe...?
Body: Steel moncoque with an Aluminium Spaceframe. Hints of Audi here...
Drive: 4WD... not sure of the final desicion on the gearbox though.
Here are the Pics...
The whole concept of the new GT-R is based on this years JGTC GT-R: Quad-cam V6 Twin-Turbo with the Aluminium spaceframe etc. From what I can gather, they've gone for ultimate weight distribution, with an engine that surpasses the RB26DETT in EVERY way.
There are pics flying around on the 'net already wich pretty much look like the finished product, except theyve added a few more vents around the place, in front of the rear wheel arches etc.
More details to come...
Cosworth have been involved with Nissan engine development since the 80's, they had a hand with the CA18DET-R in the Bluebird SSS-R homologation rally car, and again with the SR20DET in the Pulsar GTi-R. Right now, Cosworth has the VQ32DETT GT-R engine on its testbench. Nissan has sent the parts to Cosworth, and they've assembled it, and are conducting all the initial testing.
The mob who I'm getting all this info from, INSIST that the engine is a direct conversion of the current Skyline JGTC engine (which incidently is a VQ30DETT). Add an extra 200cc to it for whatever reason... all this leads to the question: Is the JGTC Skyline running Motor-assisted Turbos? And Direct Injection? Thats one of the major reasons why the VQ32DETT can put out big power, yet being in accordance with the Euro 4/5 emmissions laws.
The Bodywork. All the pics so far have indicated a very "subdued" look, without any spoilers and wings and things. Well, as far as I know, it's the actual bodywork itself, coupled with underbody diffusers and the like, that will give the new GT-R excellent down force. Right now, all those pics off the web, and in the magazines are "close" to what the final GT-R will look like, but NOBODY KNOWS FOR SURE. The front and rear end details are still in "Clay Model" stage, and nothing (as far as I know) has been decided on yet. All I know is that, there will be big bonnet vents, diffusers, and underbody aerodynamic aids.
The final GT-R pricing is estimated at around 8,000,000yen/car. Thats reasonable, if you take into account the engineering costs of the BNR32 GT-R, which topped out at around 10,500,000yen/car. And we all know Nissan lost alot of money making the R32 GT-R... hopefully they'll break even this time!
The R34 GT-R was late to show up, so the Japanese are expecting the same to happen here, and what they say is "early 2005".... shit. That could change though. (edit: Nissan Prez Carlos Ghosn put the new GT-R release date back to 2007 at the earliest... will let you know if this changes)
Disclaimer: All I'm reporting is what comes out here in Japan. Until know, I've seen or heard NOTHING about a possible V8 powered GT-R to be sold in the US. THATS NOT TO SAY THAT IT'S NOT TRUE!!! The Japanese won't be getting a V8 model (if there is one) so I guess that translates into bugger-all reporting of it here.
/Rezz
https://www.sau.com.au/forums/topic/20719-the-new-gt-r/
  • Replies 173
Subaru has been saying for a while that they have eliminated Turbo lag, but can't find anywhere how they've actually done that.
Those specs sound pretty promising, but personally i'm hanging out for an absolute bahnstormer of a V8TT :) starting to look like wishful think tho :(
where'd u get the info if u don't mind me asking?
cheers
https://www.sau.com.au/forums/topic/20719-the-new-gt-r/#findComment-434413
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
