hey guys got a r33 with bad brake squeel,i got the rotors machined and bendix ultimate in there and they still squeel the guys at the shop reckons the pistons are getting stuck out and that i should try and bleed them then if they doesnt work i will have to overhaul the calipers, wat do you guys reakon my best option is????
Edited by bwebbie1
https://www.sau.com.au/forums/topic/207227-bad-brake-squeel/
well most squeal can be cured with:
installing the factory anti squeal shims
using copper grease, or the special anti squeal paste
champhering the edges of the pads if not done from factory
re-bedding them in
but, I have a set of pads. Endless CC-R, and they squeal no matter what. Hot, Cold, New, Old with shims, without shims they are just a noisy pad. you shouldn't have that problem with ultimates though.
im having the same problem with mine only at real low speeds "just befor stoping" where can i get the factory anti squeal shims?? i remmeber the guy who was instaling my pads took them off and threw them away cuz the breaks were bighting while they were on...
iv tried everything appart from changing the brake pads which is what im going to do but i think will still not solve my problem.. so it could be that small peace of mettal "shims" that shoulda been there..
re-bedding them in
i have the same problem aswell same pads aswell still working on the problem sum people might not like this but i couldnt stand the "squeel" anymore so i took them out rubbed them on some smooth cement and they stopped for about a month now they only do it every now and then and only a bit aswell might save your ears for a bit only a quick fix but
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
