um lol u seriously wanna compare a GTR to a GTS... well.. hmm
there's no comparison.... if you can afford it get a GTR, if you can't GTS. If you want sumfin that's drivable every day and won't scare the pants off ya, then get a GTSt. GTS is too boring... mines a daily driven and is basically my run around car. Can't wait to get my weekend car next yr :O
It depends on your wallet size... 40k should see you in a GTR, 19k should see you in a GTSt, 15k should see you in a GTS. What's can you afford?
https://www.sau.com.au/forums/topic/20730-gtr-specs/#findComment-435054
JAGR33 is close to the Mark as usual I sold my old 97 for $48500 about a year ago had done 50,000kms only small modes such as Power FC, pods, injectors etc. Damm I miss that car. V Specs go for slightly more.... Find me a 97 for 35G and I will buy two!! Mine had 250kw at all fours wiht budget mods so easy to get more power from.
https://www.sau.com.au/forums/topic/20730-gtr-specs/#findComment-435449
Guest 180sx_nissan_guru
JAGR33, it aint that hard. shit i drove past a car yard the other day and they had a white R33 GTR sitting in under all the commodores. you just gotta look around. look in dealerships AND look localy, like around the streets, it aint that hard.
or if your really desperate just go and import one, should save you a few.
https://www.sau.com.au/forums/topic/20730-gtr-specs/#findComment-435472
My GTR is a 97 and 2 years ago it cost well over 50k. The car was in very good/excellent condition.
Nowadays, you'd still be looking at around the 50k mark for a good condtion 97 model.
95 models are around the low-mid 40k mark. I infact know a 95 model in excellent condition being sold for 43k if anyone is interested.
https://www.sau.com.au/forums/topic/20730-gtr-specs/#findComment-435792
dont argue with jack... he's BIG and scary lol!
but there is NO was you'll get one for 35 G's.
dont bother arguing with the guys that have replied here, cause they all own(ed) one.
QUOTE OF THE DAY:
tell him he's dreamin
:D
https://www.sau.com.au/forums/topic/20730-gtr-specs/#findComment-435818
well see the thing is i was just wondering if cops will be looking out for high performance cars and well i have two options get a GTR straight out or get a GTSt and then trade in the GTSt and get a GTR when i 'm off my P's
What dya recon would i get busted?
Or would you say as long as i'm not speeding or the cops don't have a reason to pull me over i'd be fine?
Or i'm i sure to get busted?
Thanks
https://www.sau.com.au/forums/topic/20730-gtr-specs/#findComment-435893
Good R33's over here in Perth are still around the $50k mark unless you want a smash repair job. Series II's will be around the $55 - $60k mark for a good one.... Mine's a 95 and cost me $49k last year.
Oh and 260 - 280kw at the fly is waaaayy over the mark for a stock GTR. Maybe 220 - 240... Though very easy to get that with minimal mods....
I've owned a GTST and the GTR and they don't compare. A GTST is a good car and is better than anything aussie, but a GTR is in another stratosphere. Apples and Oranges if you try and compare the two....
my 2c
Brett
https://www.sau.com.au/forums/topic/20730-gtr-specs/#findComment-436117
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
