mind if i ask a couple of questions??? with all u experience people out there. i am sure u can help me. thanx....... =)
1. Wat is the maximum boost with a stock skyline turbo?
2. Wat turbo is good to replace a stock one?
3. Wat does the turbo upgrade kit contains? For example the one in GReddy.
4. Where can i get one?
DRIVE SAFE !!!!
https://www.sau.com.au/forums/topic/20758-hie-people/#findComment-436555
LET ME SAY SOMETHNIG IN CAPITALS I READ SOME MAGS AND BEFORE I BROUGHT MY LINE I KNEW THAT STEVE (SST) KNOWS ALOT ABOUT SKYLINES PLUS U HAVE GRANT FROM PER4MANCE WITH THEIR KNOWLEDGE AND THE FOURM WE ALL CANT GO WRONG (speaking from exp ) they will set u right (stock turbo,fmic,zorst,261hp at 10psi)
https://www.sau.com.au/forums/topic/20758-hie-people/#findComment-436575
maximum boost on stock turbo no more the 13psi i pretty sure 14 psi is pushing ya luck
asking what turbo is good to replace stock one is like asking a chick what they want for christmas, everything! depends what your after in power terms
as for what is included in a turbo kit, again depends what sort of kit you get, genrally you can get kits consisting of manifold, turbo wastegate if needed and all the other bits and pieces needed for a full no fuss bolt on kit :P
where can you get one? any of the performance shops in perth: Per4manz turbochargers, Xspeed, Evo R, Works Auto etc........
adrian :(
https://www.sau.com.au/forums/topic/20758-hie-people/#findComment-436739
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
