ok guys so just had an Autronic SM4 fitted in my 32 GTR and have found 4wd light is on and always in RWD mode, (dont get me wrong this is fun but not why i wanted a GTR)
so i have checked the attessa computer and i am getting 21 flashes which if im correct is the throttle sensor or circuit.
Can anyone tell me if this is a mechanical fix problem or is it somthing in the autronic??
thanks you Lee
https://www.sau.com.au/forums/topic/207606-quick-attessa-question/
I had the same drama when I fitted a Wolf to my GTS4. The (factory) ECU passes a throttle signal through to the ATTESSA computer.
Advanced Engine Management (makers of Wolf) have a "black box" solution. Maybe Autronic has something similar.
  • 11 months later...
hey guys :)
ets: 4wd control unit right?
ems: engine management/control system?
ok ok im unsure about all the uhm, technical terms but hope you get it anyways... :P
Have installed a new ems in a friends r32gtr. Engine runs fine but we havent worked out all details in the atessa vs ems. Vill splice the tps signal(?) back to the ets, but what about the rpm signals that schematics show goes from ems to ets? Are they relevant for getting 4wd working or just tells ets that engine is running and 4wd can be engaged. Problem with this is dont know what sort of signal the ets wants when recognizing engine rpm, or maybe a positive 5v feed is enough to just say, hey engine running... with a rpm based signal it gets more tricky since we dont know what frequency it likes to listen to...
well just some of my projects right now trying to get this r32 sliding in the snow here with all 4 wheels spinning like crazy...
later on my r33 gtr will get the same treatment, would that be about the same as this? (4wd stuff vs new ems)
so i will try to get back with some info on this later...
ok so this works fine. just plug in tps signal to ets and its back in 4wd! :D
(might need a grounding wire also shown in eccs section in manual)
might need a slight recalibration on tps to get it just right... (adjust tps unit postition on throttle bracket)
dont know if i missed something, but rpm signal to ets seems to have no effect on anything important... guess ill just skip it for now.
Edited by dundersmurfen
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
