hi guys
i gave the wrong oil to my mechanic.
The motul website sez motul 300gear oil is for non- LSD diffs and ive got a r32 gts-t
it cost a packet too. those wanks at autobarn, I said to the guy "are you sure?" and he said that "motul Gear Competition is only for the GTR"
im i gunna hafta chage it?????
it should be alright with the Vicious LSD, however if you have a clutch pack type such as a 1.5 or 2 way, you'd need a LSD type oil,
failing that, you can go get an LSD additive to add to your current oil, sould get a small tube of something to squeeze into the diff
To be on the safe side i would change it....
Never take advice from guys from autobahn/repco or any of those kind of shops... If they offer you advice just smile but dont take any of it into consideration. :)
Why didnt you mechanic notice when you gave him the bottle?
You can do ur diff oil your self... isnt too hard. 1 bolt down the bottom of the diff drains your oil, another bolt on the side up the top to fill it up with.
You can pick up a little hand pump to get the oil in there which you can keep for next time you do either gearbox or diff! ... Too easy!
Hope this helps~
THis one seems like a good idea as well...
Edited by br3ndan
hey, god i wish my girl was as fast at replying as you guys hahhaha. thanks for the input.
it MAY be ok, i gave the car to the mechanic tonight and i HOPE he hasent started yet.
ill call first thing in the morning FINGERS CROSSED.
will the LSD additive be ok long term, is this a common thing to do???
its quite common, and its perfectally fine to do so, LSD oil is just normal gear oil with an LSD additive already added.
as i said, if its a vicious diff, it wouldnt matter if u used non lsd oil or not...
its the stock diff so im guessing its a vicious r200 right.
if so its all sweet and the guy at autobarn fluked the right answer (ill never give em credit for anything)
can someone confirm?????
Give the distributer a call, probably the best way of getting the right information. Also autobarn, repco etc. have brochures on the oils, which will give you an accurate listing to what oil you need to use... The guy serving you obviously didn't look it up and that's a big no-no as autobarn is now liable for any damage done to your car if it turned out to be the wrong oil.
  • 4 years later...
I prefer herbal products as they are safer. These Indian ones are great. proventil albuterol My friends were curious what happened that I lost some weight and look joyful. When I revealed my secret they also decided to use Acai berry.
proventil albuterol
proventil|albuterolbuy Proventil Inhaler
proventil inhaler generic
generic albuterol
salbutamol generic
buy lamisil no perscription
differin cream 0.1 45g
acne cream differin
Go spruik your witchcraft, hocus pocus formula some where else you thread grave digger!
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
