Gee - poor Liz. So she left an oil slick from wakey into town so people can drift a bit on their way home :D hehehe thats nice of her..
Hope she sorts it - bit of bad luck.
Ive got to get some better brake fluid and a new silicon joiner which blew apart.
Hows this... lost brakes and then car stopped boosting (all at same time) whilst coolant temp hit about 120 deg and coolant started boiling! Thought id fcked everything.
Dodgy duct tape on the joiner got me home. Could hear air escaping as soon as I looked like hitting boost
Cant believe the best I could get was 1.24! Im reading non turbo silvias doing 1.24s. I've got almost 250rwkw.. Geez I must be bad.
1.14 is a really good time chris! Check this out
http://www.themaseraticlub.com/CMA_Newslet...0(04_Track).pdf
Edited by benl1981
  • Replies 202
Dave, yeah man - flat out in 4th, jsut gone past the tower, BANG!!
scared the crap outta me!!
all good though, no other damage! dunno how it came off either! :D
now you jus gotta try harder and get the other one off.
uh-oh what did liz break this time. where do we send the trailer.
chris - you lost the plastic inner guard ont he intercooler side right? they always blow out, don't bother trying to put it back in, it will just happen again
how did the FH go michelle? is it ok there now the track is smoother?
ben...you should definately heal toe. start practicing every time you drive and you will get the hang of it.
or if you are not confident getting it right, leave your down changes until later in your braking, ie if you are doing 100 and hit the brakes dont change down into 2nd straight away, wait until you are near the end of your braking. Its always tempting to rush everything- just take a breath then change down
You'll be right James - just get the sway bars from the GB thread :D
I need to relook at my settings for camber/caster and the sway bars!
Oh, I need a new diff also....
It went great, its a whole lotta fun to drive :D:D:P its me that has to learn how to trust it with braking and cornering faster. I did have some overheating problems and had to pack up early but I had FTOD for a while which was exciting but then got pipped at the end.
Ben - practice heal toe around town, and don't let the name trick you, in reality its toe heal or toe side of foot.
Michele,
That thing would be freakin hard to drive! Man, if it took me ages to get in and out, I'd hate to see how long it take for me to get the hang of starting at and then driving!! :D
Great day today...how hot was it!..nice mix of cars there which was nice to see.
How hot was everyone elses oil temps? 35deg day..mine was reading at one stage 110deg.
poor liz hope she is ok..i was behind her when smoke was just coming out of her car, and coming down the straight with S13, silvia straight off the track n i nearly followed.
oh how many times did that blue MR2 loose it!
Michele,
I'm struggling with the gears, but it handles like a dream
nice pics you got of Chris there Michele. Wish you got a little clip of him trying to get in your car (was going to say cockpit then but that sounds so wrong) - that was funny to watch. Had the old arm wobble going (like me on a bench press with little weight
Still thinking ive got issues: 1.24 with semis (2nd hand though) and 240+rwkw!
Edited by benl1981
did you get the instructor to have a sit in lap with you?
Its okay, you can still call it a cockpit with a lady driver, alternatively you could call it the box office :D
Actually, it was funnier watching him try to get out - by the time you're strapped in there, it can get quite claustrophobic until you get on the track, then you don't think about it.
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
