Melbourne’s auto show is host to Holden’s 60th anniversary celebrations, and to mark the occasion, the Australian brand has revealed its Coupe 60. Designed to combine sports and luxury for the momentous occasion, the Coupe 60 takes from the best of what Holden has to offer.
Shorter than the VE sedan by nearly 60mm, the Coupe 60 combines stout proportions with taut styling that gives both the impression of race-track speed and road-going comfort. Huge 21″ wheels wrapped in high-performance Kumhos give solid traction, which is a necessary considering the 6.0L V8 under the hood.
Special four-point harness restraints at all four seating positions add to the race-feel while still maintaining comfort and safety. Special details in the interior or highlighted with a distinctive shiny red leather, and metal surfaces are finished in dark gunmetal and satin chrome.
The designers hope the car will make it to production, and since the Holden line could use a new Monaro (GTO in the States), maybe that’s where this car will find a home.
https://www.sau.com.au/forums/topic/208270-new-holden-coupe/
  • Replies 75
It's too big.
If they would flatten it a bit have the wheels sitting higher in the arches, they would be on to something. Also extend the headlights so they are wider across but thinner.
edit: get rid of that medallion sized front badge too.
Looks nice. Front bar is way to much like a normal VE commodore, should be more unique for a "New Monaro". The back looks a bit too arched, very similar to the Mercedes CLK coupe. Interior looks very nice, ,love those seats. Love the pillarless look between the windows, not sure how strong that would be for the roof though.... Overall looks good though for a concept.
It's been some time but it looks like they got this one right.
Nice one!
i dont like the interior but that thing looks dead sxc
Agreed. It is a typical Holden Interior. The seats aren't too bad :) but those rear seats look uncomfy as hell, not very friendly if you want a quickie with the missus in the back :yes:
The VE shape lends itself well to the coupe design. I think it looks good. Have you guys seen the LS7 sedan HSV made? http://www.drive.com.au/Editorial/ArticleD...ArticleID=49261
Yeah. It's about time they popped an LS7 into something over here :P
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
