That's correct, most people are flat past the tower. The quick cars (aka Skylines/Supras/Porsches) are usually 180+ there, with a slight lift/brake tap for the kink approx 200 metres further on.......
Giant's 32 would be better than 400 klm/h there I'd say.
Edited by Marlin
  • Replies 101
400 ? typo ?????
and yea, im not gonna bother with lakeside till they have semi realistic noise restrictions =\ a stock HSV or anything with some grunts would prob be above 92 at the top of a gear going along that straight.
400 ? typo ?????
400? No, of course I'm not serious, just a sarcastic quip mate.
That's fair enough, but I don't think a stock anything would get pinged. The only one pinged the other day was a racing 993 air-cooled Porsche with open pipes. Johnnyo's 300+ rwkw Gtr wasn't bothered at all...... neither were HEAPS of other cars.
Went out for a private track day at Lakeside yesterday with about 20 other cars (M3's, Aston Martin, Porche, 6L supercharged holden ute, commodores, GTST, 200 SX, etc, etc).
Gotta say the track is awesome compared to QR. No cars had any problems with the 92Db limit. My car (no side pipe) was 82Db on the drive- by (and was the loudest too by the way).
Whilst there are a lot more walls and barriers around the place, it is a very rewarding track. Main straight is a blast although the "kink" can be a little unnerving at high speed.
If you have never driven the track before (as was with me), I can highly recommend it.
Start off gently, get a couple of sessions in and before you know it you are going twice as fast as you think you can through some sections.
Hopefully they will keep it open forever, great track.
Didn't do any stationary 5000rpm tests - just fly-bys and the occasional take off.
There were some pretty growly V8's and the likes - mine isn't exactly the quietest of cars either.
None of which exceeded the readings at all.
Hey,
New to the forums and new to skylines, Just brought my self a R34 GT-V and have been looking for somewhere I can let loose legally.
I know what some of you are thinking, WTF u doing wanting to race a NA skyline for? well you have to start somewhere. and I have big plans for having one of the most powerful NA skylines around.
Anyway, I live on the coast so Im not too far away from lakeside. what are the requirements to be able to take your car out on the track?
Thanks
Hi Grunta,
If you want to get into track days, sign up at www.TimeAttack.com.au click the Join Now button at the top right and fill in the details.
To do sprints you need a road worthy car, long sleeve non flammable clothing (100% cotton like jeans and long sleeve shirt), covered shoes and a helment.
You will also need to purchase an AASA license to do Lakeside or Qld Raceway which you can get from the track admin on the day for $55
Paul
Hey macca, the aston peaked at 94db on hard takeoff when the valves opened up, but was well under 92db on the main straight.
Cheers,
Shane
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
