i thought i had the right of was as well, however that little part where he is is inbetween the 2 sides of east boundary road. 1 person told me he has the right of way because he is in the intersection. :confused:
however if it was just 2 normal streets i would ave the right of way???? im confused , nearly had a few problems earlier on this afternoon :D
Whether you have right or way or not, if I was in that situation (which I am every now and then), I'll make my way forward slowly and make sure I'm ready to pounce on the brakes if the other guy comes out...
It's a very iffy situation right there, and not uncommon either.
yeah thats what i was like, everytime there are 2 cars there usually each driver is like wtf??:confused: i'll give way to you, no i'll give way to you..... there really should be instructions of some sort on that corner :D
i might email my pic to vic roads and let them know about the problems people have on this intersection.
Isn't there a giveway sign at the carpark exit. My dilemmma is when you are both at a cross street from opposit directions and you both have a give way sign and one of you wants to turn across the other. My solution is to play safe and sign for the other guy to go first.
If two or more drivers at an intersection are facing give way or stop signs then the signs effectively cancel each other out. The drivers should proceed as if there were no signs controlling the intersection, following the basic give way rules.
The above is a quote from Qld Transport Web page
As a rule, if a vehicle is leaving private property he must give way to all street traffic. Unless traffic signage is present.
In this case im not familia with the area, but it looks like orange vehicle is leaving a shopping centre (car part) and even if the scenario were opposite. and he was proceeding straight and u were turning u would still b in the right
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
