The car is actually a jzx100 chaser. When I picked it up it still had jap spec fuel. I filled it up with 98ron and now im home (the sticks) I have to use 95ron.
Its gotten worse as the fuel got worse.
Could this be a problem?
https://www.sau.com.au/forums/topic/208465-miss-idle/#findComment-3688985
dave when i picked my car up from compliance it was set at 0 degrees base timing
they mite do this because of the high ron fuel over in jap and then wen some young dickhead hopes in the skyline puts in unleaded thrashes it and it doesnt detonate lol
15 degrees advanced ftw lol hmmm i rkn check timing first aye
https://www.sau.com.au/forums/topic/208465-miss-idle/#findComment-3689495
what gap are your plugs dave?
i remember when my stock coilpacks were stuffed, so i gapped mine down to around .6 to stop the miss fire on boost
i noticed with the really small gap on idle it would sit there miss firing its ass off, but drove fine under load not miss firing
i then tried another set i had there which were 1.1 gap and it stoped the miss on idle but yeh spark would blow out from crappy coils lol
https://www.sau.com.au/forums/topic/208465-miss-idle/#findComment-3690346
    • Just had this happen to me too.  R32 GTR.   Also broke "just before going out onto the track" - someone up there is looking out for us... Very scary since I was about to do a narrow street course with zero run-off and curbs everywhere. Many people on here upgrading to billet uprights and R35 bearings?   Or buying new OEM knuckles?  I am not keen to replace with another s/h 30 year old fatigued part.
    • Top off with distilled water and see what happens. If you keep losing coolant then you know to start looking.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
