Damn. Did it have to be saturday?!
Unfortunately, the cruise is all geared up for the Saturday. It's a long drive so we'll need the better bat of the day to to the full round. Is there any chance you can make it on the Satuday?
  • Replies 59
Damn, I read this thread thinking it'd be a good chance to take the R out for its first cruise and photo op but it's a Saturday! :/ Can't make it :D
Ah well, there'll be plenty more cruises to go to in future.
Just to sum up the numbers so far:
Chris R31
Skyhigh33
Lavz 90
Freespirit (Maybe)
Fc3s13bt + Friend
Voox (Maybe)
Basti (Maybe)
Dngrus (Maybe)
For all the "maybies" could you please confirm yay or nay by the 18th? Just need to get a firmer grip on who's coming and who to wait for.
Just posting an idea for a new cruise taking in the beach, city and mountains.
Full tank of fuel reccomended at first meet point
DATE: Saturday 19th of April
TIME: Meet at 2:00pm depart 2:30pm
TOTAL CRUISE TIME one way including stops (Approx): 4 - 4.5 HOURS
Meet Point: Car Park on the Esplanade between Maidstone St. and Rose Street in Altona (See attached image from Google Earth) Go over the West Gate Bridge and as soon as you step off, hang a left into Cook Street and continue towards Beach Street.
Approx 45min Drive to First Stop.
First Stop: Carpark on Marine Parade at the end of Blessington Street in St. Kilda. Approx time of arrival 3:15pm. We'll probably hang around for about 15 - 20 minutes.
From here we'll head to Dandenong Road (Pincess Highway) and travel as far as Warrigal Road where we'll turn onto the Monash Freeway. Take the Wellington road exit (C413) and continue to Clematis. Here we turn Left on the C412 (Belgrave Gembrook Road) Continue through the roundabout in Emerald, continue about 6kms and go straight though the roundabout onto the C411 towards Woori Yallock. Once we hit Woori Yallock turn right onto the B380 todards Yarra Junction.
Approx 1hr 45min drive to Second Stop.
Second Stop: Yarra Juntion Carpark Arrive at about 4:30. I don't know it's exact location, but it's on the left as you enter Yarra Junction from the City Ther is a big oval and toilets, you can't miss it. It's a gravel carpark. Again.. we'll probably be around for about 20 minutes. Have something to eat etc...
From Yarra Junction we'll continue towards Noojee, and on towards Mt. Baw Baw. I think there will be a $5 cover charge per car to enter the Baw Baw National Park. If people don't want to enter the park we can just turn around at the gate and head back down the twisties.
Approx. 1 Hour drive to Final Location.
Final Location: Carpark at the top of Mt. Baw Baw. Arrive at about 6:00pm. Stop here for a while and if the numbers are up take some pretty impressive photos.
There are some awesome fast twisties leading up to Noojee and losts of sharper, slower twisties towards Mt. Baw Baw.
Matt..Well done Great looking cruise you have going here... :D
It would be good if i could make it .But i will be up at Oran Park that weekend..Dam it..
But what i will do is drum up some support for you.
I will spread the word and see if we can get more cars.
I will also mention it at the SAUvic G Meeting on Tuesday night..
Good luck with the Cruise mate
ps. If you in South Melbourne on Tuesday night
pop in to the meeting..All are welcome..
Cheers Wayne (RCHOO)
SAUvic Events Co-ordinator
Thanks for the plug RCHOO! Any additional exposure would be really appreciated. This really is a long cruise, so the more people the better!
Does anyone else need any more information about it?
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
